05-09-2018, 02:32 PM | #15 | |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
So what is your interest in logging DYNCYL? Do you have something specific you're trying to see with this log? |
05-09-2018, 09:59 PM | #16 |
Drives: Camaro 17 SS Join Date: Jan 2017
I log a lot of things. But I'm interested in the changes that I've made to my motor. Especially when adding boost.
05-11-2018, 01:58 PM | #17 | |
Inj. pulse width peaks at 7.0 ms @3500 rpms and decays down to 6.2 ms at the end of the run. Fuel rail pressure is 1500 psi and tapers up to 1900 psi at the end of the run. LPFP maintains at about 70 psi. Here's the log. If you want the HPL log, I can send it to you. |
05-11-2018, 02:04 PM | #18 | |
What is your AFR should be lambda .82 or 12.0
www.jannettyracing.com
05-11-2018, 02:50 PM | #19 |
Thanks Ted, I'll take your comments to heart. I just felt like I was running out of fuel, but couldn't pin it down.
The HPFP is following the HP base desired pressure table pretty closely, so I'll up that somewhat to get the HPFP to ramp up a little quicker and higher, if there is any room left mechanically. Why is an injector pulse width time, such as this 7 ms, such a problem? Would some reduction of the SOI base table from a high of 386 to 360ish help any? I'm surprised that I didn't log the AFRs. ER goes from 1.0 to.82 at tip in. |
05-11-2018, 03:11 PM | #20 | |
I higher flowing pump will reduce the inj MS. Ted.
05-11-2018, 04:24 PM | #21 |
Thanks Ted for all of your effort on this. I don't think we appreciate how much time you put into this forum to educate us.
But I'm still curious of the why on the limitations on injector pulse width. |
05-15-2018, 04:51 PM | #22 |
Drives: 2016 Hyper Blue 2SS w/White Rallye Join Date: May 2016
Just had to share that I enjoy reading this info. Thanks
05-15-2018, 09:39 PM | #23 |
05-16-2018, 07:30 AM | #24 | |
6 milliseconds is the injection window for complete combustion. When you get past that a lot of nasty things start to happen. Ted.
05-16-2018, 08:25 AM | #25 | |
Your comments gave me the inspiration to spend some time last weekend investigating what's going on. I played around with the fuel pressure settings of both pumps. I did about eight full pulls with slowly upping fuel pressures of one pump, then the other. Surprisingly, I was able to get below 6 ms throughout the entire pull by pushing the LPFP to 62 psi desired normal pressure. And by rebuilding the max desired pressure table for the HPFP to a max of 17 kpa, the pump pressure never went below 1980 psi and ramped up 2400 psi on the top end, which seems to be the mechanical limit of the pump. Looks like the fuel rails are staying full and pressurized. Very interesting results! I have some dyno time scheduled next Friday and the tuners will put the car on the dyno and confirm my results and ideas before I declare victory. |
05-16-2018, 08:53 AM | #26 | |
05-16-2018, 09:38 AM | #27 |
I need to confirm actual AFR vs. commanded on the dyno next week. One of the main reasons for going back.
I will tell you that Edelbrock's SOI base table is very different than the stock table. Edelbrock extends out to 389 verses 335 for the stock table. |
05-16-2018, 09:56 AM | #28 | |
Tail pipe sensors are in accurate and there is a time delay so don't rely on them. Put a AEM X series wide band O2 sensor in your head pipe before the cat.
