11-02-2018, 10:37 PM | #43 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Yes, that's why when doing testing we measure and record all torque values, instillation torque and residual torque (some engineers wanted Torque to Tighten and some wanted Torque to Loosen but we always used an ST wrench). It's very time consuming to measure all the torque values at the start of a test, middle of a test, and end of test. And by all, I mean all. That self taping screw holding trim pieces to the dash/door panel/anything has a torque value. And most are over tightened when serviced at the dealership.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
02-18-2020, 02:32 PM | #44 |
Drives: 2019 Chrevrolet Camaro 2SS Join Date: Feb 2020
Wheel Torque 2019
The 2019 manual is definitely updated to 140 lb ft. To bad my torque wrench is suppose to go to 150 but it will only get to 129#. So I borrowed my neighbors that is suppose to got o 150# also. Turns out his only goes to 130#. Lesson here is that two different brands of torque wrenches that are suppose to be 150# max won't reach that number, buy a higher rated wrench. Just ordered a torque wrench that will go from 25#-250#. Keep wrenching friends.
02-19-2020, 08:26 AM | #45 |
...and the bump from DOWNTOWN!!!
Had to search to find a 2018 torque thread
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
02-19-2020, 08:50 AM | #46 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
Glad this came back from the depths because I definitely just assumed it was 100. Oh well, the wheels didn't fall off.
Also, whatever lube tech put them on last definitely didn't do it to spec. Some of them I had to sit there for a minute with my Ryobi impact to get them off, others were barely more than hand tight. |
02-19-2020, 09:04 PM | #47 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
When I did my brake fluid flush, torquing the wheels was the most difficult part...but it is at 140!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
02-20-2020, 08:24 AM | #48 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
If you don't mind sharing, what did you order, and what do others recommend for a torque wrench where 140 is about in the middle? I still need to get one.
02-20-2020, 09:42 AM | #49 | |
Drives: 2006 Lexus IS350 Join Date: Mar 2017
Though I've not invested in an "Icon" item yet, Harbor Frieght's Icon line is supposed to be rather on-point :
02-20-2020, 09:52 AM | #50 |
Sure, why not?
I own some HF things, but I am not sure I want to trust anything from them requiring precision. Maybe those are fine, but I am a little leery of them. My current tq wrenches are Matco and Bluepoint.
02-20-2020, 11:44 AM | #51 |
Drives: SS 1LE Join Date: Oct 2017
Yeah, I definitely wouldn't trust a torque wrench from Harbor Freight... lol
02-20-2020, 12:49 PM | #52 |
This makes me wonder, how critical is it that lug nuts are to spec. Mainly how much variance before you start to see an issue. I mean, it seems like most cars lug nut specs are measured in uggas and/or duggas.
02-20-2020, 01:08 PM | #53 | |
Sure, why not?
However, when you are talking about a vehicle that can go around 180 mph, I start to want to be sure that things are attached according to specification, since the forces involved at high speeds are greater, and if anything goes wrong if could be very ugly. So, a little "click-click" would give me some peace of mind. Not that I drive terribly fast on public roads, but still...
02-21-2020, 07:27 AM | #54 | |
02-21-2020, 08:05 AM | #55 | |
Sure, why not?
I do like air tools for breaking free really stubborn fasteners and for running things in or out, but I like to do final tightening with a tq wrench. A lot of this comes from my background of working on motorcycles. Motorcycles tend to be a lot more "spec sensitive" than cars and trucks so you have to be more careful working on them, but the desire to do precision work carries over for me.
09-06-2020, 09:05 AM | #56 |
Drives: 2018 Chevy Camaro ss 1LE Join Date: May 2020
That’s crazy, I’ve done a bunch of track days torquing my wheels to 100lbs. Never had a problem, one track I hit 142 Mph. I checked after each session, the wheels never lost torque. I’ve raced cars for years, 140 is really tight, I never heard of torque specs that high
