11-08-2021, 07:31 PM | #1 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
UMI Performance Roto-Joint Rear Trailing Arms
SOLD
2010-15 Camaro UMI Performance Roto-Joint Rear Trailing Arms https://www.umiperformance.com/home/...w-roto-joints/ The Roto-Joints are tight and have never made noise. No bind articulation. Cosmetically, there is a lot of road rash. PayPal only. $185 Shipped
11-27-2021, 08:42 PM | #2 |
GPI Sales Consultant
Tempting...
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
11-28-2021, 09:53 AM | #3 |
Drives: 2015 2SS 1LE Twin Turbo Join Date: Jun 2018
11-28-2021, 10:04 AM | #4 |
Drives: camaro Join Date: Jun 2021
11-29-2021, 01:04 PM | #5 |
Drives: 2010 Camaro SS Join Date: Sep 2021
Does it come with the wrench for adjusting the rotojoint?
Send me a PM. |
11-29-2021, 02:38 PM | #6 |
Yes, I modified a pin spanner wrench to fit. But, I doubt it would be needed as the Roto-joints have stayed tight.
11-29-2021, 04:07 PM | #7 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Is there a reason you went with this over the Detroit speed adjustable ones? Especially when you had Detroit speed everything else. Thanks!
12-11-2021, 02:36 PM | #8 | |
There is no reason these should be adjustable. You don't want to mess with the rear caster. This UMI arm, IMHO, is the better design. Plus, the Roto-Joint never made a peep. And probably less expensive than the DSE.
12-11-2021, 02:37 PM | #9 |
SOLD
12-14-2021, 06:56 PM | #10 |
Thanks for the info. I will be looking at going this route for the Z
12-15-2021, 10:29 AM | #11 |
You're welcome
