Old 04-26-2019, 05:13 PM   #1
mano_camaro
IYAOYAS
mano_camaro's Avatar
Drives: 22 1LE 2SS M6 Riverside Blue
is my rear half shaft broken?
I started hearing a knocking noise from the rear end after my first track day with this camaro SS. I checked the bolts connecting to the rear differential, and they are still tight with the colored marks still matching lines. I pulled on the half shaft while i was replacing the rear diff fluid and it has just a tiny bit of play. Anyone else experience this?
I probably blame it on the stiff BMR trailing arm while taking tight corners at speed on the track, most likely putting a heavy load on the half shaft.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold
2018 black Camaro 2SS M6 Redline Edition/Traded
2016 summit white Camaro RS V6 M6/Traded
mano_camaro is offline   Reply With Quote
