Old 07-02-2017, 05:03 PM   #1
Jsreo
Drives: 2017 2SS Manual
Track Day Check List
I picked up a 2SS 6M back in April & will be doing my first track day at Road Atlanta in 3 weeks & wanted to list what I have done already & what I plan to so, feel free to weigh in with any suggestion on anything that I may have missed. Car has 2800 miles on it & will probably have 3500 on it by the time the track day gets here.
I did an oil change & differential fluid change at around 1200 miles. Also installed a strut tower brace a while back as well.
Completed today
Installed larger defectors & smaller splash shields. This was a bit of a PIA but you can really see how it will channel so much more air to the front brakes. I doubt I will ever run on a track without these.
Brake fluid flush with Motul RBF 660
Installed Phastek SS brake lines
Installed EBC yellow stuff brake pads
Installed Z1 add on's rock guards
Installed Harry's lap timer pro on my IPhone & bought the windshield mount
Planned to do before track day
Oil change with Motul X-clean (dexose 2) 5W40
Apply Road Warrior Plus paint protection behind doors, probably do some blue tape there as well
Install CG Lock seat belt locking device. This allows you to cinch up you lap belt as tight as you want without impacting shoulder belt
Will change rear diff after track day using OEM fluid
As you can see I am mostly working on braking, I have ran on RA several times and there is a lot of hard braking from very high speeds which is why that is where I have put most of my effort so far.
Do I have all of my bases covered or am I missing something
TIA for any recommendations
Jsreo is offline   Reply With Quote
Old 07-03-2017, 01:14 PM   #2
Extreme Dimensions
Extreme Dimensions's Avatar
Drives: 2016 1ss Camaro
i did everything you did cept i did rear diff fluid change before and ran with oem pads even though i had brand new powestop track pads in my garage haha
car did great btw! you still on stock tires/wheels?
Andrew Bettridge
Account Manager
Extreme Dimensions
1-714-278-8000 EXT 17
andrew.bettridge@extremedimensions.com
Extreme Dimensions is offline   Reply With Quote
Old 07-03-2017, 01:34 PM   #3
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Good quality brake fluid, pads and more importantly track alignment are essential for the track day.Also get some good quality tire pressure gauge and torque wrench.
May I ask why you added the strut tower brace? I would never consider adding a strut tower brace on a car that already has some understeer.
glamcem is offline   Reply With Quote
Old 07-03-2017, 01:40 PM   #4
DFW1LE
DFW1LE's Avatar
Don't forget to bed your brake pads.
Old 07-03-2017, 01:41 PM   #5
slick3
Drives: Garnet Red - 20 ZLE
Sounds like you got your basis covered. Give your rotors a once over. I would check the torque on all your wheels (COLD) as well as take them off and verify key suspension components look safe. Grab a wrench check your sway bar endlinks, visually inspect bolts and rod ends. Most of the suspension components have lines on them to verify rotation. If they dont have lines on them buy a pen and do it yourself. Just a generic pre-track suspension check is always a good idea. While your under there check for leaks and verify coolant level etc.
I will add to your "bring to the track" list...
Water
Airpressure guage
Extra quart of oil
Spare brake fluid
Shop towels
Gloves
Extra blue Tape
Somethign to clean your windshield.
Torque wrench and a socket for wheels
Jack and Jack stand.
Lawn chair and some form of shade. Big umbrella would be nice.
slick3 is offline   Reply With Quote
Old 07-03-2017, 03:13 PM   #6
Jsreo
Thanks for all the replies & ideas
Track alignment, good call, I will get that done thanks. I suppose can just use the SS 1LE alignment specs from the HP supplement right?
I am still on stock wheels & tires, & have good quality torque wrench & tire pressure gauge
I will bed in the pads before hitting the track, I will have 500 to 700 miles on them as well so they should be good to go
Don't believe the strut tower brace does much except look cool, I will remove it if I notice undo understeer, very easy to do, only a few bolts.
These all make sense too, thanks. Road Atlanta has a big covered area to hang out in that keeps you out of the sun so I should be good without an umbrella
Water
Extra quart of oil
Spare brake fluid
Shop towels
Gloves
Extra blue Tape
Something to clean your windshield.
Also - forgot to mention that I did purchase track day insurance - $257 for 90% replacement plus $10K property damage coverage - hopefully never to be used but made sense to me for a new car
Thanks again
Old 07-04-2017, 08:02 AM   #7
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
A physical checklist. Don't count on memory alone for remembering everything, every time, and don't check anything off until after you've actually done it/packed it.
Norm
Old 07-05-2017, 11:59 AM   #8
mbar
Drives: 2016 1SS
EBC yellow should work for first time ever at the track. On the 2nd / maybe 3rd event you will melt them away.
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 07-05-2017, 03:56 PM   #9
mbar
Drives: 2016 1SS
Norm
Norm....with this long of a list you forgot to mention a trailer to carry it....
Old 07-06-2017, 12:15 AM   #10
OminouSS
OminouSS's Avatar
Drives: Red Hot track candy
Norm
Legit
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
OminouSS is offline   Reply With Quote
Old 07-06-2017, 07:32 AM   #11
Norm Peterson
Let's just say that experience has been an unforgiving instructor . . .
Norm
