06-16-2017, 09:27 AM | #29 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
06-16-2017, 04:23 PM | #30 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
I mean we can say this or that would have happened, but theres ground for both sides of thought. Pro-BoP vs Pro-Run what ya brung. but at what point do things get outta control??? either way, i'm still cancelling anything tomorrow and doing my tradition of watching all 24 of it, straight through however, appreciate the humor in the post.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
06-16-2017, 04:47 PM | #31 | |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
By going wider (and as a result taller) tires in the rear, I retained the original rake also which should also help reducing the understeer. With the slicks or R7, 305 SQ setup might be better since overall grip level is already better than Nt01s or streetable R comps and keeping the balance (going from 325s to 305s) wouldn't be a downgrade.
06-25-2017, 12:26 AM | #32 |
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4 Join Date: May 2015
06-25-2017, 03:23 AM | #33 |
I tested the car with and without the wicker bill at the last event.
After running the car without the wicker bill, I didn't feel any loss in traction/ rear grip but the car felt like it was a bit faster on the straights. I checked my trapped speed on the main straightaway and it was about 2 mph faster on the average than with the wicker bill, ~136mph vs ~138mph respectively (both recorded with external 10hz GPS so pretty accurate on straights) I have to note though, the ambient temps were slightly lower (say 2-3 degrees) on the later sessions when I ran it without the wicker bill. However, the car didn't feel sluggish or heat soaked in the previous sessions either so I still think wicker bill was adding some drag.
06-25-2017, 03:29 PM | #34 |
Drives: Red Hot track candy Join Date: Oct 2009
This cars whole problem, if you want to call it that, is understeer. Period. I can fix that with tires alone. I don't need to go down the path of aero unless the factory did all the testing for me. Change to a 295/315 or 305/325 setup, in a sticky compound and call it a day. If you're on tighter, slower courses then go SQ. It's taken 6 months to prove that having thrown all the magazine dribble out the passenger window. You should just simply never consider aero until you've worked out all fixes you can with rubber, first. Just complicating a process.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
06-25-2017, 04:10 PM | #35 |
Never drove a ZL1 but having now driven my SS 1LE on a track for a few sessions I can defo vouch THIS car doesn't have any "understeer problems" in stock form. It simply goes where it is pointed on turn in, has fabulous mid corner rotation and good exit. Now a ZL1 handles a bit differently from what I've read and it would not surprise me as the F is heavier. But, I'd agree on balance that solving any handling issues via aero is likely the last place I'd be looking for. The problem IMO is that aftermarket shops sell a whole bunch of add ons that may make a car look cool, but that's a different path altogether. Then folks lean on info pertaining to different cars (like Z/28) yet that's another different car, different suspension, sways, track width, etc etc. Apples to oranges...
06-25-2017, 04:41 PM | #36 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
would anyone expect any difference between the SS wing and the 1LE blade spoiler on a road course?
06-25-2017, 05:34 PM | #37 |
If the F spoiler is the same on both cars then I'd expect the same down force on the R to maintain proper balance. But it may depend on sways, rake and track width. If the latter are not the same then down force might not be either EDIT: to achieve a proper balance overall.
06-25-2017, 08:46 PM | #38 | |
06-25-2017, 08:57 PM | #39 | |
#becauseracecar
The square setup helps a lot I've noticed. |
06-25-2017, 09:12 PM | #40 |
If 1LE (don't know about non 1LE cars) understeered, Randy wouldn't be faster in it (vs Z28) around Laguna without Multimatic suspension, without LS7 motor and without near slick Trofeos. Also, I wouldn't just beat my PB yesterday, which i set in my Vette on NT01s. NO. 1LE does not understeer. Instead, it is a superbly balanced car which goes where pointed. Even Randy noted that. But, maybe folks that do experience understeer have a messy alignment, or changed the track width with after market wheels, or over drive it, or perhaps just need more instruction. PS I've been doing it long enuf to know when car is as close to neutral as possible. And apparently Randy thinks so, too
06-25-2017, 09:34 PM | #41 | |
#becauseracecar
06-25-2017, 09:41 PM | #42 |
Fair enuf. That's why GM built a 1LE as a track version. If both of them handled the same it wouldn't make sense for anyone to spend several thousand $ just for a black hood wrap Peace.
