08-17-2016, 09:53 AM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
Camaro Momentum GT Pro DRY S Stage-2 Intake System At RPI Designs
2016 2018 Camaro Momentum GT Pro DRY S Stage-2 Intake System V8-6.2L $403.75 With Code PHIL5 At Checkout.
Unique One-Piece High-Quality Housing W/ Sight Window: A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to completely seal the auxiliary air scoop. High-Quality Tube: This system uses a high-quality plastic CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. Also included is a high-quality billet aluminum crankcase fitting provided for easy installation. This tube has a built-in resonance chamber to catch un-wanted air intake noises. High-Quality Scoop: A high-quality CAD air scoop guides cool ambient air to the performance air filter. Large 3-Layer Performance Air Filter: This Momentum GT intake system was designed around the largest filter possible to allow maximum performance and filtration. This cylindrical filter has a large oval (6-3/4" x 4-3/4") flange and is 9" tall inverted top Pro DRY S filter media. The Pro DRY S performance air filter features 3-layers of progressive finer porosity synthetic media providing maximum convenience with 100% polyurethane frame for long life and multiple cleaning cycles. Premium Hardware: Premium stainless steel T-bolt clamps and a reinforced silicone elbow coupling are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation. Note: This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles. Pro DRY S Features Oil-Free, dry synthetic media. WORLD'S EASIEST AIR FILTER Easier to service than conventional, oil-impregnated pleated media or foam filters Significant airflow increase Pro DRY S provides dramatic airflow increases for improved horsepower and torque performance with 99.2% filtration efficiency Pro 5R Features Maximum airflow, maximum gains Pro 5R provides the highest airflow levels for the largest gains in horsepower and torque for times when performance is everything Progressive filtration with protection and performance Only aFe's Pro 5R media is progressive in nature, offering 5 layers of progressively more tightly woven cotton gauze for protection levels in the high 98% range without sacrificing airflow http://www.rpidesigns.com/shop/item....ystem-v8-6-2l/ Camaro6 Forum Members Save With Code PHIL5 At Checkout. Last edited by RPI Designs; 03-29-2018 at 02:20 PM. |
08-17-2016, 12:14 PM | #2 |
Drives: 2017 M6 NFG Join Date: Jul 2016
Any proven hp/tq gains?
09-07-2016, 09:24 AM | #3 |
06-13-2018, 07:06 PM | #4 |
Drives: 17 ZL1 Join Date: Mar 2017
I have the Pro 5R on my ZL1. Don't have dyno numbers, but am happy with my purchase. It's quiet, no sucking sound or anything like that, just performs as expected.
Inside of the filter
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
06-14-2018, 02:31 PM | #5 |
Thanks for posting pictures!!
09-20-2019, 02:29 PM | #6 |
