Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 01-05-2012, 11:52 AM   #43
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
You must not have swung hard enough...
2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5
Bulldogwinters is offline   Reply With Quote
Old 01-05-2012, 03:42 PM   #44
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
I wasn't doing the swinging. I think it's more a welding **** up/lack of tools. If you saw my car in person you'd probably notice it after staring for 20 seconds from the rear: He added about 2-3 inches of sheet metal on the B pillar arch and when he welded the quarter subassembly.
Needs another pull that the puller wasn't capable of but other than that, it's good for now as a DD/fun car.
Oh, and for those wanting to see the mock up shots, I'll post 'em. They aren't bad, but its nothing close to how it's going to look (I hammered one of the tips onto the pipe without adjusting anything else.)
Zabo is offline   Reply With Quote
Old 01-12-2012, 12:04 AM   #45
Zabo
Gunning for Sixth
Zabo's Avatar
...Guess whose Pumpkin is leaking again. *raises fist*
Old 01-12-2012, 07:23 AM   #46
dmginc
dmginc's Avatar
Drives: In Circles
my pumpkin isnt leaking but my seal where the shaft goes in is...hopefully it is covered by warranty but probably not.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 01-12-2012, 07:30 AM   #47
Zabo
Gunning for Sixth
Zabo's Avatar
Pretty sure your pinion seal finally gave out. Changed mine out within 2 months of driving, rubber just gets old. My pumpkin on the other hand just isn't sealing right, so I may just shell out for a new cover and start bulletproofing the G80 while I'm at it (rather than go strange or 12 bolt/whatever).
I know my driveline shop is gonna "WTF" when I call 'em later today. This will be their 3rd attempt at sealing it up.
Old 01-12-2012, 04:04 PM   #48
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
Those tips look pretty cool. Being black they won't show dirt and soot very well which is nice. My tips get dirty after a day of driving.
Pinion seal, easy fix. I had to do it on my sisters car.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 01-19-2012, 04:53 PM   #49
Zabo
Gunning for Sixth
Zabo's Avatar
O Hai.. I iz ur brothur..
Hmm.. everything swap into this one?
I'm tempted to pull up in mine and just drive that one, leave the poor dealership bastards scratching their heads.
Old 01-22-2012, 11:05 AM   #50
Zabo
Gunning for Sixth
Zabo's Avatar
Filed the taxes today: 880 due back. Stash 250 for hotel stay with my A&P testing leaves me 630 to play with for Headers/Y-Pipe.
TSP 1 7/8s LT and ORY? Might as well finish out my TSP system.
Prolly ask for a Tune, Gaskets, Bosch O2s, and possibly plugs for the ol' 25th birthday.
Old 02-08-2012, 07:01 PM   #51
Zabo
Gunning for Sixth
Zabo's Avatar
And Headers are off the table. Instead I got my Serp belt/AC belt replaced, Right signal/running lamp socket replaced because it literally burned up/melted, and had my oil changed while it was up on the lift.
Damage: $300 bucks because the socket was more of a PITA than anyone thought.
Now that the car actually runs great again, plans have changed. Need to stash 250 for my A&P, leaving me probably another 250 for.. nothing.
Old 02-08-2012, 09:07 PM   #52
73camarolt
73camarolt's Avatar
Drives: 2002 Camaro SS
Hey Zabo how do you like your short stick? I'm thinking about buying that one but can't decide if I want to or not. It's cheap but I'm just not sure lol.
2002 Camaro SS- BTR Stage 3, 799 Heads, Bolt on's Tuned by John at Broadview Automotive.. 420hp and 400tq
73camarolt is offline   Reply With Quote
Old 02-09-2012, 12:28 AM   #53
Zabo
Gunning for Sixth
Zabo's Avatar
I'd go 6.5" if you're worried about going too short. With the bushing removed (fused to the stock stick) the stock T56 Hurst linkage almost feels like a gated shifter. Much better shift response and is a snap to install. No more bouncing out of gear unless I royally flub the shift or shift while rolling on the throttle (lockouts engage).
Nothing but praise here for the shifter. If you do go with it though, the boot will have a good bit of slack. Easy way is to get a black zip tie and with the boot turned inside out cinch it up to the shifter.
Old 02-09-2012, 06:28 AM   #54
dmginc
dmginc's Avatar
Drives: In Circles
i have the 6" one and it works great but i have the stock Hurst shifter. if you have the base non hurst one then get the 6.5".
Old 02-09-2012, 12:58 PM   #55
73camarolt
73camarolt's Avatar
I have stock hurst. I'm thinking 6.5 because I don't want to go to short.
Old 02-09-2012, 01:53 PM   #56
dmginc
dmginc's Avatar
Drives: In Circles
the 6 is perfect, tho i dont think there will be too much of a real difference over a 1/2 inch. either one is way better then the stock one.
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 611 07-01-2020 08:49 AM
Ph4r's Car - Boobies - Build Thread Ph4r Member Car Journals 42 03-20-2013 06:09 PM
Camaro5 Fest II Caravan/Convoy Thread tribone 2011 Camaro5 Fest (II) 13 04-12-2011 02:22 PM
Dumbest Camaro5 Question EVER! Beemer 5th Gen Camaro SS LS LT General Discussions 209 05-23-2010 06:11 PM
