06-02-2020, 10:22 PM | #1 |
Drives: chevy camamro SS Join Date: May 2020
who in here is running nitrous?
Haven't heard much about how the lt1's do with nitrous or what kits are recommended. What size shot is safe on sbe? I have heard the safest route is with a stand alone fuel system
06-04-2020, 01:55 PM | #2 |
Drives: 2019 Chevrolet SS Join Date: Mar 2019
I made a post on it but Im running it on my heads and cam camaro.
im doing a 100 shot but system is set up tp go up to a 200 if needed with the standalone fuel system and c16 for fuel and e85 in tank for normal driving. |
06-04-2020, 05:48 PM | #3 |
I'll look for your post
06-05-2020, 09:04 AM | #4 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
LT1 runs great on nitrous, someone here was running 9s with a 200 shot with slicks and skinnies. A "proper" nitrous system is not cheap and once all the costs are added, its within financial reach of an entry level blower kit. Most owners tend to favor the power available at all times with a blower setup vs the 4 or 5 10 second hits you can squeeze out of a 10 lbs nitrous bottle. Also, refilling bottles gets old really quick and adds up over time, take it from a guy who filled close to 100 bottles back in the day on the LS platform.
06-05-2020, 03:26 PM | #5 | |
I was already close to 600 on NA and reaching the max limit of my stock lt1 fuel system so that is why i went the nitrous route. It will allow me to run up to a 200 shot without having to upgrade my stock lt1 fuel system. On a 100 shot the car probably makes around 650 and to get to 650 on a blower set up that would need at minimum the lt4 fuel system upgrades which is around 1500 dollars, an aux pump for e85 which is 700-1000 and the blower itself which would be around 6k, so it would cost more than double to go blower and even if you add in the cost of filling nitrous bottles you could fill up nitrous bottles for a few years depending on how often you use it and still not spend the money on a blower. |
06-05-2020, 10:45 PM | #6 | |
06-07-2020, 02:10 AM | #7 |
$3500?! Holy cow I had no idea it was that much. I thought the $1k kit was all you need minus the stand alone fueling. I guess I'll just finish going NA with hopes of eventually going blower
06-07-2020, 04:35 AM | #8 |
Yep, it is not cheap when done right and can actually be more than that if you add more accessories. You can get away with an entry level $1,000 plate kit for tiny shots 100 and under in my opinion, but I wouldn't gamble a factory sealed engine with a large shot on that kit without all the extra safety nets offered in a kit done right. Only takes one hiccup, ask me how I know.
06-07-2020, 08:55 AM | #9 |
Yeah, I may have to look more into it or say screw it all together. Ive never ran nitrous and it has always scared me, so *♂️
