06-04-2020, 05:50 PM | #29 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I was quoted $15,500 for
Mag 2650 Cam kit Rotofab big gulp 103 TB Meth kit All fluids Spark Plugs Tuning for trans with dyno and street tune I had kooks headers already. |
06-04-2020, 06:07 PM | #30 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
By whom? Probably 17k if u didn't already have the Headers.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
06-04-2020, 06:16 PM | #31 |
It was in Houston. (Houston Performance Solutions).
06-04-2020, 07:00 PM | #32 |
Well not seeing a low side and e85 sensor. Which could be around 1300! From DSx plus install would take that 15,500 quote to 17k. Like I said before to you, 17k is on par.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
06-04-2020, 07:38 PM | #33 |
2 shops suggested doing meth instead of doing the low side. Now I'm not sure which way to go.
06-04-2020, 07:39 PM | #34 |
Very true, but the meth kit was $1000 dollars so you can offset the cost of the E85 with that.
06-04-2020, 07:54 PM | #35 | |
What ever wrote you go you will be happy I’m sure of it.
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. Last edited by Ron_Robinson1; 06-04-2020 at 11:07 PM. |
06-04-2020, 09:07 PM | #36 |
Asking for trouble IMO...
06-04-2020, 11:09 PM | #37 |
Explain? Have used meth before and failed? What system did you use that failed?
06-05-2020, 07:14 AM | #38 |
I’ve been running meth for only 4 months now. Will be purchasing another pump within a year so that I can send my current one out to have it rebuilt. I’ll be sending out my pumps every 12-18 months to make sure they are working great. It’s not expensive and it’ll add some security.
I prime the system everyday that I drive the car. After letting the car idle for 1min and temps come up a bit, I hold the test button down until I see green (this means it’s spraying and see and feel the idle RPM drop a bit. Then I’m good to go. The system is primed and meth it set at the nozzle waiting for boost. |
06-05-2020, 07:59 AM | #39 | |
06-05-2020, 08:02 AM | #40 |
I have a Alky control dual nozzle setups. There seems to be some other good brands at this point. But for the last 9 years I have ran alky control with no issues.
06-05-2020, 08:08 AM | #41 |
I run Alky Control as well. Tech support is awesome! Spoke with the owner himself to discuss priming and rebuilding pumps when needed. Very helpful. I have a 2.5 gallon tank in the trunk. Holds plenty of meth. I have only done about 1 1/4 mile pass, and 6 rolling pulls to +130mph. Still have plenty of meth left. Maybe about 2 gallons.
06-05-2020, 08:25 AM | #42 |
thanks for the feedback.
One of the shops said i should stay with 1 7/8 headers and regular intake size, not the Big gulp. What are u guys running?
