06-07-2022, 09:45 AM | #43 | |
Hot Camaro
When the material thickness of the rotors is near the minimum, ESPECIALLY if the two surfaces have different thicknesses from each other, the material can develop irregularities along the surface under load that are more pronounced. Still, this is likely to still be on the generally more insignificant side. The biggest concern is likely due to simply not having enough material to absorb the heat properly from braking and the brakes either "fading" or outright failing during use (much like what can happen to trucks on steep downhill grades when they brake too much). I believe the misnomer you are referring to is people referring to pad deposit / buildup on the rotors, creating pedal pulsations, as having a warped rotor. |
06-07-2022, 09:22 PM | #44 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Yep, "warping" is not what is happening. It could be a poorly mounted rotor/wheel due to corrosion/dirt at the mating surfaces or most likely, uneven pad transfer on the rotor. Uneven pad transfer layer is very common and can be resolved with a simple light cut or honing tool:
https://www.amazon.com/dp/B007INTEMC...?ie=UTF8&psc=1 Here's some reading on the two types of friction that is utilized on brake systems and the role of the transfer layer: https://www.cquence.net/blog/abrasiv...%20the%20other. And some reading from Centric that defines transfer layer and proper bed in: https://centricparts.com/getmedia/bd...c-8-2018_1.pdf https://centricparts.com/getmedia/b6...y-8-2018_1.pdf https://centricparts.com/getmedia/6c...k-8-2018_1.pdf https://centricparts.com/getmedia/fd...e-8-2018_1.pdf https://centricparts.com/getmedia/23...FAQ-8-2018.pdf https://centricparts.com/getmedia/a0...l-8-2018_1.pdf
06-07-2022, 09:26 PM | #45 |
I'd also note that some wheel cleaners are so aggressive that they can remove the transfer layer. This causes an uneven transfer layer. MeGuiar's Hot Wheels purple wheel cleaner will remove the transfer layer. I found that out years ago.
