02-12-2021, 04:26 PM | #1 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Windshield replaced...now mirror doesn't work
Had the windshield replaced. Now the frameless rearview does not come on. No lights.. Nothing.. Auto dim of course does not work either. Pulled and checked the OnStar fuse and pulled the usual F1 trunk fuse to reset the system. Still nothing
Thoughts?
2014 2SS/RS LS3/M6
02-12-2021, 05:48 PM | #2 |
You need to get the windsheild installer to give it a look. They probably disconnected the mirror wires and didn't plug them back in correctly.
02-12-2021, 06:24 PM | #3 | |
I've checked the connection. I've pulled fuses. I've checked everything. I've even checked voltage at the plug. I get 3.8v constant. No idea if it should be that or 12v though.
2014 2SS/RS LS3/M6
02-12-2021, 07:49 PM | #4 |
Looks like pin 10 on the connector(red) should be 12.5v but I only get 3.8
No idea wtf
2014 2SS/RS LS3/M6
02-13-2021, 12:54 PM | #5 | |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
02-16-2021, 05:12 PM | #6 |
Drives: 2014 Camaro 2SS/RS 1le Join Date: Jan 2017
I do this for a living, no way it's pinched, the wires sit behind the headliner, there's plenty of room. I never unplug the mirror unless I have to, just usually let it dangle. That voltage sounds low. Not sure how the installer could have damaged it. Wires can get cut, I've even had where the wires were in the glue and sliced the wires while cutting out the windshield.
Call the company, if you used a reputable company they'll get it set. Shit happens.
2014 Camaro 1LE SS/RS THE MISTRESS
02-17-2021, 03:55 PM | #7 |
Drives: 2020 GMC Sierra AT4 Join Date: Jul 2013
Obvious thing I can imagine is at least slightly cut wires. Maybe something that’s not that noticeable unless you were to open the wrap around the wires. Otherwise could be the plug itself, they could have left it dangling and pressure applied to it caused one of the pin connections at the wire. Did you check voltage at both sides of the connector and also make sure you have a good reading? Mirror side & wire harness side. Take readings on the pins and if possible on the wires themselves. I imagine the wires are very small so not sure how difficult getting a good reading is on them. Your choice is take it back to them to fix it or replace parts yourself at your own cost.
2023 Camaro 2SS 1LE Summit White
1100 - 3/23/2023 2000 - 3/27/2023 3000 - 3/28/2023 3400 - 4/12/2023 — 4/24 TPW 3800 - 4/28/2023 5000 - 5/30/2023 6000 - 6/03/2023 2020 GMC Sierra AT4 6.2L Black |
02-17-2021, 04:33 PM | #8 |
Dangling the mirror wouldn't cause a pin to get pulled, the plugs are locked in with a tab and the mirror is pretty light. I have literally let 10s of thousands of mirrors hang and that hasn't happened once.
But at the same time, if a wire was cut, it'd still read the right voltage...I think, trying to remember my high school electrical classes. Pretty weird deal though.
02-17-2021, 04:43 PM | #9 | |
02-17-2021, 04:46 PM | #10 |
I agree. I'm wondering if that's the problem. 3.8 volts is the correct reading, it may be a lot voltage circuit, and a wire might be cut in the pig tail and he's losing the ground.
