07-15-2022, 01:14 PM | #1 |
Drives: 2016 Camaro SS Join Date: Sep 2020
Strange No Start Issues
I know there are quite a few threads discussions on the starter issues. I have a 2016 SS. I am the second owner. I have had issues mutiple times over the past two years in very hot weather where the car cranks very slowly and then won't turn over. Sometimes a jump will work, other times it will jump start but all the warning lights come on the dash and it runs rough with tachometer and speedometer not working. Sometimes it simply won't crank over at all but in those cases the headlights work fine, the dash is fully lit but it can't be jumped even at the battery in the trunk. Had a new battery put in about two months ago when I got stranded but yesterday it happened again. Technician said battery checked out fine but at one point he said it appeared the alternator might not be charging but 30 minutes later he was able to jump start it and all the readings were normal.
Any guidance before I replace the starter or alternator? |
07-15-2022, 01:22 PM | #2 | |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
Sounds like the typical ground wire issue many owners have. https://www.camaro6.com/forums/showthread.php?t=586153 https://www.gen5diy.com/collections/...ground-harness |
07-15-2022, 03:54 PM | #3 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Get a newer starter, they work alot better. There has been 3 version that I know of.
Also replace start relays under the hood fuse box. Its the big ones. |
07-15-2022, 05:53 PM | #4 | ||
https://www.camaro6.com/forums/showthread.php?t=492310 Quote:
07-15-2022, 06:12 PM | #5 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
Agreed with the other guys, also, how old is the battery you have in there now?
07-15-2022, 09:55 PM | #6 |
Your starter may need replaced at this point if you have had multiple hot start failures. I recommend you go ahead and replace the starter and then put the additional engine to body ground cable on it.
Read my thread on this that Matt1LE provided. Many, many 2016 SS's have the hot start slow crank issue and the additional ground cable fixed the problem. I was plagued by it just like you. I added the ground cable in December 2020 and it eliminated the problem. Good luck and keep us posted.
07-15-2022, 09:57 PM | #7 |
I’d start with the ground wire too. I have a 22 and noticed a slow start after a drive on a warm day. Adding the ground wire seems to have fixed it for me.
