02-05-2018, 02:12 PM | #1 |
Changing Diff fluid change
I know I want to do Amsoil Severe Gear. Just have 27k miles... fun miles... and I am not too sure if it has ever been done. I want to do it for peace of mind and I am running more HP than stock. I know how to do it and have access to a lift to do it on so that makes this about a billion times better haha.
My car does not have its manual and I can't find a solid answer to any of these questions. 75w90, correct? Do I still need to put the additive in if I run Severe Gear? Amount? 2.1 quarts?
764RWHP on e85 683RWHP on 91. M6 Black on Black on Black. 1300ID's, DSX Aux Pump and Flex Fuel Sensor, Lingenfelter 2.5 upper 9.5 lower, 100MM idler, AFCO HX w/ FANS. 1 7/8"ARH exhaust to axle incl LTH, MF's, Fuel Lab FF, Lingenfelter ported snout and TB, Lingenfelter CAI, RotoFab coolant tank, NGK 2 steps colder spark plugs, Moroso catch can, BTR Stage III cam, crank case breather. Tuned by Power Labs in Idaho Falls, ID.
02-05-2018, 02:42 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Hey there, I am in the process of doing mine too. I purchased amsoil as well. I can't answer most of your questions except I know amsoil's website is correct. The oz you need and I know when I purchased, it said I still needed the additive. Although, I'm not sure exactly what would be different about the ZL1
02-05-2018, 03:15 PM | #3 |
Do you have the part number for the additive handy? I would love to get this done this afternoon.
02-05-2018, 03:51 PM | #4 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
2.1 is correct. I always use the GM fluid with the additive included..
02-05-2018, 04:12 PM | #5 |
02-05-2018, 05:04 PM | #6 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
I run Redline 75w90 ... has additive already
02-05-2018, 05:35 PM | #7 | |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
02-05-2018, 06:10 PM | #8 | |
02-05-2018, 06:13 PM | #9 |
Yes, I talked to my Amsoil supplier and that's the one he said to use.
02-05-2018, 06:27 PM | #10 |
Very interesting. I am just curious why they don't push that on their website. I didn't really go searching for it, but it wasn't in the "recommended" part for when I went to purchase the oil.
02-06-2018, 11:04 AM | #11 |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
You can get the owners manual through my Chevy app. It's free and all you have to do is add some info about your car such as the vin#.
2.1qts and stick with the delco fluid which is 75w90LS (LS additives already included). Make sure to get some sort of syringe to add the fluid. Makes the job easier and prevents any mess. Some will say you need to go do a bunch of figure 8s after.... That's ok, but all you really need to do is go take it for a nice cruise. The fluid will distribute just fine. I changed mine a month ago, and everything has been perfect since.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
02-06-2018, 11:46 AM | #12 | |
02-06-2018, 12:01 PM | #13 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
I am an Amsoil dealer. I just checked with HQ about your question. Your weight is correct. Amsoil severe gear is great with all 5th gen Camaros EXCEPT the ZL1. It is a different story. It does contain the additive for LSD, but they recommend using GM recommended for the LSA. As far as amount, undo both lower and upper plugs. Drain, install lower plug and fill till oil comes out upper plug. 1 bottle may be enough, it is on my 2010 V6. I have used this for 3 seasons of track days and all is well.
02-06-2018, 02:23 PM | #14 | |
