01-08-2018, 08:19 AM | #1 |
USA-1
Are 1LE rear shock mounts required for 1LE shock upgrade?
Hey all,
So I have seen different opinions on this, but I have some 1LE shocks/struts ready to go on, but do I NEED the rear 1LE shock mounts to install the 1LE shocks, or is it just the preferred method? Thanks!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
01-08-2018, 09:56 AM | #2 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
If you have a 2010 I would say yes. If you have a 2012+ w/FE4, maybe not. I replaced them when I installed them on my 2013 and can't remember if the part nos were same. I would regardless as the bushings age.
Also check - you might need to install the 2012+ FE4 lower control arms for those shocks. The mount points could be different.
01-08-2018, 10:46 AM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
i don't think it is 'required' but it is definitely recommended. the ZL1/1LE rear shock mounts are an upgrade over the FE3 or FE4 pieces.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
01-08-2018, 04:52 PM | #4 |
Drives: cars Join Date: May 2011
There's not much difference when I had both in my hand at the same time and did measurements. Same durometer but slightly more surface area contacting the washer.
01-08-2018, 07:31 PM | #5 |
USA-1
Synner, thanks man! Looks like I can save the money then and put it towards a ZL1 rear sway!
01-09-2018, 07:27 PM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
The better choice would be the Z/28 mounts IMO
01-09-2018, 08:37 PM | #7 |
USA-1
Oh boy, didn't know that was even an option! Do you know the part number and cost? What makes them better?
01-09-2018, 09:15 PM | #8 |
05-05-2021, 09:45 PM | #9 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Bumping an old thread.
I recently installed Z28 rear mounts on my 2010 SS with 1LE shocks/struts on Hotchki 1 inch drop springs. There seems to be more rake and the wheel gap in rear seems higher? Is this due to the Z28 mounts thickness or the 1LE struts? |
05-06-2021, 05:46 AM | #10 |
Drives: 2015 Z/22 Join Date: Aug 2015
How much higher was the rear than the front before the install compared to after? Rear sits a bit higher than front from factory. Were all of the bushings "timed" properly during install? Torqueing the suspension arm bolts when the arms are not in their resting position (car on the ground) will create extra tension in the bushings when the car is on the ground, causing the chassis to sit higher than it should.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
05-06-2021, 02:34 PM | #11 |
They were done by a professional. Sure he did that.
I think the Z28 hats have a thicker bushing which probably accounts for the difference. I was hoping to see if that is fact and any remedies |
