10-08-2017, 02:32 PM | #1 |
Drives: 2013 zl1 Join Date: Aug 2017
Track engine oil weight
What weight is good for track and street use. Doing more track use then street use. New to the track world and appearently you should be using a different weight.
Sent from my HTC 10 using Tapatalk |
10-08-2017, 04:49 PM | #2 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
I use 15w40 t6
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
10-09-2017, 08:16 AM | #3 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Another subject very much up for debate. Depending on what type of track usage you're seeing (full on road racing vs. 20-30 min HDPE's), is it really necessary? I also track my car, and get great Blackstone reports back using a premium synthetic in the weight GM recommends, which in my case is a 5w-30. Some of the other guys with more engine building experience should chime in here soon, but I don't believe it's necessary or even recommended to up the weight just because your pushing the car the way it was designed.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
10-09-2017, 11:57 AM | #4 | |
10-09-2017, 01:07 PM | #5 | |
Drives: 2013 BMW M3 Join Date: Jul 2016
10-09-2017, 03:57 PM | #6 | |
Resident nomad
Sorry, ZL1dad, not intending to derail your thread. I think you'll get a mixed bag of "don't change weight" to "move up to a 40w is ok", and I certainly don't think a 40w is too much. I think when we LS3 owners start trying to run LS7 track weight oil (15w-50), I personally think it's too heavy for the LS3 bearing clearances, and I've read such many times.
Sold:
10-09-2017, 07:48 PM | #7 |
Drives: cars Join Date: May 2011
Has a lot to do with how well you maintain temps. I have a massive oil cooler so no reason to change weights. If your car is dual use then add on a thermostatic cooler and don't change weights. If you do then you'd need to drain and replace after every event.
10-09-2017, 11:14 PM | #8 | |
10-10-2017, 09:53 AM | #9 |
Resident nomad
Holy crap, then I wouldn't change. 230 is nothing for the track! I can see 230+ driving in the city (Phoenix area), and regularly see 270+ on hot track days. Adding a Mishimoto cooler soon.
Sold:
10-10-2017, 03:21 PM | #10 | |
10-10-2017, 03:51 PM | #11 | |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
I will not take a car on a track, even an HDPE without replacing the fluid. I have no idea why GM did not start with a good fluid. They also tell you to replace the oil with 15w50
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
10-10-2017, 04:25 PM | #12 |
Sounds like you're talking water temp not oil as that number is unrealistic for daily driving let alone on track. It's being cooled by 200 degree water, it aint gonna get below your water temp tracking or on a cooldown lap. You need to hook up a real gauge and get an honest oil temp.
10-10-2017, 04:48 PM | #13 | |
I debate using rotella t6 all the time because it's good stuff but I probably won't until the warranty is up because there have been rumors about people not getting warranty work covered because they used "diesel oil" instead of whatever the other kind of oil is. I don't really believe they are going to those lengths to test your oil but I push my car too hard to take any chances. If you're changing your oil regularly any reputable synthetic will be just fine. Last edited by Notilloc; 10-10-2017 at 06:28 PM. |
10-10-2017, 05:14 PM | #14 | |
