Old 08-19-2019, 01:02 PM   #1
HartfordRacingCaptain
HartfordRacingCaptain's Avatar
Drives: 2017 Camaro 1SS, 2023 Colorado Z71
SS Track Deflector Bolt Fatigue
Instructions for installing and uninstalling the brake calipers to take on and off the track brake deflectors calls for a reapplication of red Loctite and 148 ft-lb torque to the caliper bolts.
My understanding was that red loctite was meant to be a permanent application. If this is happening to support track days multiple times a year, isn't there some sort of fatigue working on the bolts? Is there a heightened risk of shearing if performed often (i.e. 6 times a year)?
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow
HartfordRacingCaptain is offline   Reply With Quote
Old 08-19-2019, 01:44 PM   #2
VinnAY
Drives: 18 1SS/1LE
I might prefer blue loctite, yes the red is more "permanent".
Old 08-19-2019, 01:48 PM   #3
If failure were to occur at any time and they saw that you used anything other than what their instructions said to use it sounds like the sort of thing warranty would be denied for.
Old 08-19-2019, 02:00 PM   #4
VinnAY
Drives: 18 1SS/1LE
You put it on with red and 148ft lbs it'll be on there til the end of time.
Old 08-19-2019, 02:01 PM   #5
VinnAY
Drives: 18 1SS/1LE
On and off as you wrote it would negate the use of Red.
Old 08-19-2019, 06:02 PM   #6
Red and 148 ftlbs are what the GM supplied instructions say to use, Step 12.
I'm not challenging your logic BTW, makes total sense to me.
Old 08-19-2019, 08:23 PM   #7
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
LOCTITE® 272 is a red, medium viscosity, methacrylate-based threadlocking adhesive with high strength. With a fixture time on steel of 10 min, brass 5 min and stainless steel 15 min, it is ideal for applications where any migration of the adhesive must be prevented. Can tolerate slight contaminations of industrial oils. Suitable for all metal fasteners. It has a breakaway torque on M10 bolts of 23 Nm.
you are torquing to 200nm, the breakaway torque for 272 is 23nm. You should be okay. 272 is used because it was designed to handle more heat than the other red colored formulas but it also isn't as strong as them. As for bolt fatigue, it will happen. I'm not sure of the expected life cycle GM has for them. Every manufacturer and application is different.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 08-19-2019, 09:00 PM   #8
Appreciate the insight, thank you.
Old 08-20-2019, 06:22 AM   #9
VinnAY
Drives: 18 1SS/1LE
ah so we're not talking solely the red color but different formulas that are also red in color.
Old 08-20-2019, 06:42 AM   #10
Guess so, I thought all red was intended to be permanent.
Old 08-20-2019, 07:22 AM   #11
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Leave your track deflectors and heat shields on and don't worry about it
