08-17-2019, 05:25 PM | #15 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
OP - you might want to try this.
I had some major water spots from the previous owner on my trunk lid. I tried all types of products, and I was about to do a color sand with 2000grit, when I thought I'd try the Flitz. Glad I did, because it removed the water spots, but I still needed to buff out some fine scratches...see pics. This is much easier than having to color sand the trunk lid. Here's what I used as a final step...Collinite #845 and SiO2 with Carnauba Spray.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
08-20-2019, 12:55 PM | #16 |
Drives: 2019 Red Hot 1SS "Scarlett" Join Date: Jul 2019
OP - try a lighter polish and a pad with medium coarseness on your dual action polisher. Meguiar's #83 and Klasse AIO are great products.
Even something like "Meguiar's Ultimate Polish" which you should be able to pick up at any Wal Mart, should get those watermarks out without removing too much material. |
08-20-2019, 01:50 PM | #17 | |
From the look of it, some Pinnacle Advanced Swirl Remover would do wonders for that panel. |
08-21-2019, 06:10 AM | #18 |
Drives: The shiny ones. Join Date: Mar 2010
08-22-2019, 11:23 AM | #19 |
Drives: 2021 Acura RDX SH-AWD Advance Join Date: Aug 2019
WD-40
08-22-2019, 03:46 PM | #20 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
08-22-2019, 08:12 PM | #21 | |
Flitz is what removed the water spots...hence I mentioned I still needed to buff out the light scratches. What I failed to mention is what I used to buff out the fine scratches, but since this was "How to remove water spots" I mentioned Flitz. Have you tried Flitz to remove water spots? The removal is NOT superficial. Maybe I should list the steps I took to remove the water spots with ALL the products I used, I was afraid what I posted here with the pics was incomplete/confusing...and it was. My apology.
08-26-2019, 11:09 AM | #22 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Here is a guy from TRC testing 5 methods of water spot remover.
Wheel acid was the best for removing water spots.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
Thread Tools | |
