08-16-2019, 11:06 AM | #1 |
Drives: '17 Camaro SS Join Date: Mar 2017
Need advice on how to remove these water spots
Hello, I got a few different looking water spots on the back end of my car that I am not sure exactly how to deal with. Any suggestions on how to deal with these would be great.
roof: for reference, I have polished my car about a year ago (took days of 6+ hrs using a Random Orbital )and since then have changed my washing method. I don't think I need another polish yet since there are minor swirls on the car, so I would like to leave that as a last resort option if possible |
08-16-2019, 12:01 PM | #2 |
Thank you Al Oppenheiser!
08-16-2019, 12:11 PM | #3 |
Drives: Chevy Camaro Join Date: Jul 2019
Vinegar works like a champ. Mix half and half with water.
08-16-2019, 12:16 PM | #4 |
08-16-2019, 12:30 PM | #5 | |
08-16-2019, 12:31 PM | #6 |
Drives: Camaro 1LE Join Date: May 2018
I had very good results with meguiars water spot remover on my truck last month. It got sprayed by a sprinkler pretty good. Make sure you follow the instructions on the back of the bottle.
08-16-2019, 12:44 PM | #7 | |
i have some of that stuff also works good thank god only had to use it once
08-16-2019, 02:05 PM | #8 |
Drives: The shiny ones. Join Date: Mar 2010
My experience with water spots like you have is you have to machine polish to remove them. Our Orange pad & Correcting Polish would do the trick.
Remember once they are removed to put n some good protection to keep it from happening again. https://adamspolishes.com/collection...tion-detailing |
08-16-2019, 02:09 PM | #9 |
CLR didnt work, it seems the only option is to polish.
08-16-2019, 02:10 PM | #10 | |
08-16-2019, 08:15 PM | #11 |
Was worth a shot. Wheel acid would be one very big step stronger and can dissolve even aluminum oxide... but it could also wreck the paint. And it's HF based, so very very bad juju if you get it on bare skin or breathe the fumes.
So since CLR didn't dissolve the spots at full strength then yes a machine polish is your next best bet. Much less risk of bad things happening to you or the car with a polisher! |
08-17-2019, 09:55 AM | #12 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Carpro Spotless works well, but it may come down to a strip and polish, had that happen a few times...sucks but sometimes the only option.
08-17-2019, 11:42 AM | #13 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
A polymer paint sealant like McKee's High Def Sealant, Chemical Guys Jet Seal, etc. is your best defense against hard water spots.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-17-2019, 02:31 PM | #14 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Last resort, and it will work if done correctly.
Color sand with 2000grit and then polish out the fine scratches. If you do go this route, don't press hard when sanding and use a block, you don't want to remove all the clear coat, just enough to remove the spots.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
