08-09-2019, 05:00 PM | #1 |
Drives: V6 2LT Camaro Overkilled Join Date: Jun 2018
Replacing the touchscreen
Recently my touchscreen started to act on its own. I am planning to replace it. The problem is there are a lot of different part numbers. I am not sure if I buy the same it won't have the same issue. The part number is 84015998 and the car is from 2016 and has the 8' display with spectrum lighting. If I buy a unit from a 2018 or 2017 and just take the screen, w/o the other parts, will that be possible?
08-10-2019, 07:25 AM | #2 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
I would take it to the dealer if you are still within your warranty!
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
08-10-2019, 08:13 AM | #3 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Also there is a good chance it isnt the touch screen, it is the HMI module that is going out causing the issue. While you can buy the HMI module it isnt plug and play. It has to be flashed with the firmware and then married to the VIN for your car by the dealer.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
08-10-2019, 12:53 PM | #4 |
The problem is I am not from the US and there isn’t a dealership of GM here. I now it might be the HMI, but replacing the touchscreen is easier.
08-12-2019, 08:56 AM | #5 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Have you got a multimeter and checked to see if you have power/signal at the HMI and at the touch screen and check for cut/loose wires before you start throwing parts at it?
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-12-2019, 10:22 AM | #6 |
my did that too. the fix was to simply unplug the negative battery cable for 20 mins or so. It has not done it since and that was 2 years ago.
08-12-2019, 02:21 PM | #7 | |
Tried that and the thing with pulling the fuse, but didn't work for me. |
