08-03-2019, 08:35 AM | #1 |
Drives: 2018 2SS Bright Red Join Date: Dec 2017
bug splatter removal
Howdy gang.
I live in Northern Maine (The County) and the bugs are a plentiful up here. I still cringe taking the Camaro out knowing that it will be painted with bug guts. I have put on a ceramic coating and used polish and an orbital, used Reload and keep it clean with Chemical Guys show shine spray. What do you guys and gals do to remove the bug splatter without removing the underlying layers? I am not up to washing the car everytime because that gets old. Is that spray shine sufficient you think to use by itself as long as I keep the area wet with it and use a clean microfiber cloth? I would think a bug/tar remover spray would remove the under layers? Thoughts? Thanks everyone. Have a great weekend! Lee
Lee
Cyr Plantation,ME>>>boonies 2018 SS Camaro 2022 Silverado 2500HD Big Red |
08-03-2019, 11:33 AM | #2 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
PoorBoy's World Bug Squash. Diluted 1:10 for paint. Use full strength to dissolve bugs in the radiator fins.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com Last edited by KirkH; 08-03-2019 at 01:13 PM. |
08-03-2019, 11:53 AM | #3 |
Thank you Al Oppenheiser!
Turtle Wax Bug and Tar Remover. Set to stream, squeeze very lightly to put a small dollop on each bug. Wait 2 mins. Wipe clean. The solvents in it will not hurt your finish, but do a very good job of softening hard bug parts so they don't scratch.
https://www.walmart.com/ip/Turtle-Wa...hoCQuwQAvD_BwE |
08-03-2019, 01:39 PM | #4 | |
Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
If I am out and get a few on the front, I either will take out the Wagner steamer -or- get a microfiber and soak it in the hottest water possible, wring most of it out then set on the bug area. The water/heat seem to break-up a majority of the mess and if you've got a good coating under it... typically it wipes totally off. (Point here being I try to avoid using any sprays, cleaners and such)
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
08-03-2019, 01:52 PM | #5 |
Retired from Car mfrs....
Actually there’s a lot of ideas here they’re all good, I use a combination of things above. No matter what you do you can’t get bugs out of a grill without melting them, and that’s why bug squash works very well then hit with a force of water.
for the paint when it’s really bad like fla love bugs, I get 2 hand towels soaked In the hottest water that I can stand, and lay them on the paint. Your paint sealants are intact and the bugs come off easily. However, this heat will screw with wax, another reason I never use it. Either coating or sealants for me. Just remember: never scrub the paint with anything…
08-03-2019, 02:52 PM | #6 |
Thanks all for the ideas.
I ended up getting a clay bar and detailer spray and went real easy with that. Took care of the bug problem and did not see any residue afterwards. Followed up with the shine spray and looks good again.
Lee
08-03-2019, 03:34 PM | #7 | |
Clay is an abrasive. It will remove ceramic and it will cause marring. I always follow a clay bar with a machine polishing. That being said...there are new clay bars that claim to be very light and not mar or remove ceramic coating. But I haven't tested it.
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-08-2019, 01:07 PM | #8 |
I have a bottle sprayer that fill with water, then about 5-10 drops of Dawn dish washing soap.
I spray the bugs liberally and let it set for a few minutes. Spray them down again, then wipe them off with a MF rag. I always follow up with detail wax or Mothers spray Wash n Wax. Works great, never have to scrub a bug, just wipe off. At a car show I just use Mothers Wash n Wax on what few bugs I get. |
