06-29-2019, 06:07 PM | #1 |
Long hauler
Fitting ZL1 exhaust
I've been researching and got a few questions I hope someone can assist me on.
I received a ZL1 exhaust off a '19 ZL1, full catback with one point cut off which I intend to get welded back on (exact shown below). I took a look underneath the car and noticed the differences between mine and the ZL1. Mainly the ZL1 was a manual and doesn't have the AFM valves that mine does and there's a portion near the cats that is a different design from the v6 that the SS and above have. I'm pretty sure it'll fit fine but am concerned whether there'll be issues without the AFM valves, I don't see any way that they could be monitored as there are no plugs after that point but I'm not sure. Regarding the NPP functionality, I do intend on just running it as if Fuse 51 was pulled and it to be open all the time. I don't think there'll be a huge sound increase but I mainly am doing this for the quad-tip look and very slight sound increase. Last edited by Bumbleboy92; 06-29-2019 at 06:10 PM. Reason: Coherence |
06-30-2019, 11:35 AM | #2 |
It might be easier to cut the suitcase muffler off the ZL1 system and have a muffler shop weld it in to your system on your V6 Camaro instead of trying to fit the ZL1 system to your car. The pipe size is bigger and I would think the head pipe bends and connections are different than your system and I’m sure that you would throw a cel with your AFM not plugged in. A good muffler shop could give you advice and info on what you are wanting to do I would think!
06-30-2019, 02:30 PM | #3 | |
Drives: 2016 2SS Convertible Join Date: May 2012
06-30-2019, 03:21 PM | #4 | |
Long hauler
No actuator is connected, I can only see this spring valve with no wires to it. |
06-30-2019, 04:30 PM | #5 |
I didn’t realize that the valves were different on the V6. Agreed that they don’t seem to be monitored electronically.
Tags |
compatibility, exhaust, fitment, retrofit, zl1 |
