06-07-2019, 04:00 AM | #1 |
Drives: 2019 2ss 1LE Join Date: Mar 2019
Burnouts
Is there a trick to dumping the clutch on these and smoking the tires? Do I have to turn stabil trak off? Sometimes I'll dump the clutch and it will fall on its face
06-07-2019, 05:08 AM | #2 | |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Traction Control/ Electronic Stability Control The Traction Control System (TCS) limits wheel spin. The system turns on automatically every time the vehicle is started. StabiliTrak/Electronic Stability Control (ESC) assists with directional control of the vehicle in difficult driving conditions. The system turns on automatically every time the vehicle is started. . To turn off TCS, press and release Y on the console behind the shift lever. i illuminates. . Press Y again to turn TCS back on. To turn off both TCS and StabiliTrak/ESC, press and hold Y on the console behind the shift lever until i and g illuminate. . Press Y again to turn on both systems. See Traction Control/Electronic Stability Control 0 207. |
06-07-2019, 05:51 AM | #3 | |
Drives: None at the moment Join Date: May 2018
06-07-2019, 07:15 AM | #4 | |
Drives: 2017 Camaro SS Join Date: Nov 2018
https://my.chevrolet.com/how-to-support
Kevin
Luceo Non Uro |
06-07-2019, 07:29 AM | #5 | |
Teach a man to fish... |
06-07-2019, 07:32 AM | #6 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2019
I tried to do a smoky burn out for my toddler (he loves it when i do it with the vette) and I was not able to light them up. I had all the nannies turned off too...
06-07-2019, 08:15 AM | #7 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
Question has been asked multiple times, owner manual showed to many people. A simple search would have helped. Instead of telling you to search he gave you the complete info. Thanks to him!
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
06-07-2019, 08:47 AM | #8 |
Drives: E92 BMW M3 Join Date: Oct 2012
LOL, seems like someone needs a safe space to go cry. Thanks for the very helpful post Jerome.
J-Rod Built and Matt@FSP Tuned |
06-07-2019, 08:54 AM | #9 |
06-07-2019, 09:56 AM | #10 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
Cold tires on asphalt is another story, turn off nannies, apply throttle, slip clutch, spin to your hearts content. |
06-07-2019, 10:27 AM | #11 |
Obviously I know if you turn everything off you can spin away ssnd yes I read the owner's manual but I've also let my dad drive my car he ripped a massive burnout with stabiltrak on so answer that JEROME
06-07-2019, 10:34 AM | #12 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Stabilitrak can still be on with Traction Control off.
MJK3888 Instagram Link
06-07-2019, 10:52 AM | #13 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Stabilitrak controls yaw. Traction Control controls tire slip. Two separate systems with two different missions. Btw you can also go into Competitive Mode and spin rear tires as you please. Hope this helps.
06-07-2019, 11:14 AM | #14 |
I know that stabiltrak can be in with traction control off, what I'm saying is sometimes I dump the clutch with stabil trak on and traction off and it won't let the wheels spin and other times it has let me spin them. I was curious if it has to do with rpms or something
