01-25-2019, 01:18 PM | #1 |
Drives: 2017 ZL1 with Lingenfelter 720hp Join Date: Dec 2018
Supercharger/Procharger
I have a 2017 2SS Camaro completely bone stock with A8 automatic. I am going to be purchasing some type of supercharger or procharger here soon. I am not wanting to race this car every weekend. Just want to add more power and have good drivability. I wanted to get feedback on what type is the easiest on the motor, has good drivability, and FAIRLY EASY TO INSTALL (since I will be installing it myself). Also, anything that would come with a tune as well to where I wouldn't have to get a dyno tune, since my car is stock. I appreciate any feedback.
01-25-2019, 01:43 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
The Procharger is easy to install, never did a PD or LT4 conversion. I would steer you away from the can tune, there are many email tuners and as long as you go ahead with a wideband and a HP Tuner, you would be all set. You are really leaving a LOT on the table with a can tune.
01-25-2019, 02:06 PM | #3 |
Hope you consider the 2300 Magnuson Heartbeat. Its about a 8-12 hour install depending on your mechanical skills. You should see about 550 rwhp and about 560 rwtq on 93 octane. We do offer a warranty with our superchargers if you leave it stock. Most people can't but its an option.
01-25-2019, 03:51 PM | #4 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
I would recommend the procharger to you. Their superchargers are very reliable and often can be had for cheaper than the competitors. The procharger installation also doesn't require any cutting of plastic/foam, harness zip ties or modifying of any stock parts. the installation is far less time consuming vs roots style blowers.
If you are not interested in installing your decided supercharger yourself, I would be willing to lend a hand if you bring it up to my shop. Would only take the weekend. best of luck with your choice; it can be hard sometimes haha
01-25-2019, 07:55 PM | #5 |
Procharger or ECS is the easiest to install and is the route I would go for a DIY install. I normally do my own work but chose to have my Whipple professionally installed because they are more labor intensive.
2016 NFG 1SS A8
01-25-2019, 08:15 PM | #6 |
Drives: 2016 Garnet Red 2SS A8 Join Date: Jul 2017
I agree that the Procharger is a fairly straight forward install. The LT4 fueling upgrades were more involved and took about the same amount of time as the supercharger did. Their install manual is very helpful but I believe all the PD manufactures are as well.
2016 Camaro 2SS - Auto - MRR 017 - Garnet Red
P1X w/ Stage II IC, LT4 Fuel System, JMS Voltage Booster, MMS Catch Can, JRE Off Road Pipes, JRE Tune |
01-25-2019, 11:51 PM | #7 | |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
My two cents would be to figure out if you are going to use a canned tune or if you are going to go the custom route. If you are planning to just go with a canned tune, the Maggie is a great choice because, like Laynlo said, you can keep a full warranty. The standard tune from Maggie will be pretty darn good. For sure it will be killer on the steet until you end up going a little crazy and adding more stuff (happens to everyone once you feel the massive difference). I am biased to Maggie because of the great experience I have had... Trying to be more unbiased: If you are gonna add some additional items, which almost everyone does, then I would say pick a tuner, talk to him about what you want to accomplish and follow his advice. At the end, each tuner probably has their preferences and they have great experience/expertise and as a result they are probably best positioned to help you out. I am a big fan of Jannetty Racing (as I lose my impartial opinion)... Good luck. Look forward to great results.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
01-26-2019, 06:09 AM | #8 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
I myself was going back and forth on a centrifugal vs PD. I do think the centrifugal is the better way to go in the way it outputs power (mid range on up), but myself could not spend my money on the Procharger kit because of the pulley drive system. I was just not confident the adapter that pinches the crank pulley as a solid solution.
After months of research I went down the road of the East Coast Superchargers kit. This is a kit basically built by Vortech, however it is specified with a Paxton Novi 1500SL head unit vs the Vortech Si head unit. With the location of the S/C and the rotation of the S/C, it limits which head units work, and the Vortech choices are the Si (pretty limited in potential) or the Ti unit which is almost overkill. The Paxton units are made by Vortech now, but the Novi is a pretty capable unit on the LT1 with capability of 900hp. The upswing is the design of the kit. Rather than drive from the crank, it utilizes the stock 6-rib accessory drive, however it runs off of a jackshaft then uses a cogged belt from the j/s to the head unit. ECS says this design has enough belt friction to up to 14lbs of boost (max output) with no issues. The kit is extremely well built and it is a very solid mount. Plus, which amazes me, is that the noise is minimal. With the hood down, you can't really tell its not a stock car. The way Vortech does things is they don't make a "low cost kit" with options, they just have a "Stage II" equivalent design out of the gate. very large intercooler, all alum charge pipes, billet BOV, etc... is all standard. You can run 500hp up to 900hp with changing nothing but pulleys (a 5 minute job), no worry about limitations other than do you have enough fuel pump / injectors. Cost is close to the P/C Stg II setup.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
01-26-2019, 07:45 AM | #9 | |
01-26-2019, 09:55 AM | #10 | |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
This lower pulley isn't going anywhere!.
01-26-2019, 10:18 AM | #11 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
If I went with a centri supercharger, I’d also lean on ECS over ProCharger. Mostly because of the cog pulley and as I understand it, it is less intrusive. Meaning, nothing gets removed from the car to make it work. I’ve heard from some 1LE guys that some items needed to be removed to work.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
01-26-2019, 03:47 PM | #12 | |
I made the call on what I thought was best for me. Now after working with the ECS kit - I think it is a good design, but the logistics of working thru ECS / Vortech isn't the smoothest. I filled out all the information on the engine, mods, etc... they asked for. I ended up with the wrong pulley on the jackshaft and no pulley for the head unit. And a bunch of fingerpointing on who's fault it was. Getting the pulley off the jackshaft was a bear (a ton of red loc-tite on the bolt and down the key way). I got the head unit about a week after my order from ECS, but 3 weeks later still nothing else. Contacting ECS was just a bunch of "we will check and call/email you back" with no response. You can never get the people with the answers on the phone. Call Vortech and they will tell you to call ECS. The install instructions are all from Vortech - no accommodations for the Paxton blower, so you are left to figure some things out (things like how to plumb the PCV to the air filter, how to mount the air filter, how to set the BOV, etc....). To this day I was supposed to get a start tune, but never got a response from anyone and just ended up getting a email tune from my tuner.
01-27-2019, 04:00 PM | #13 |
I like the ECS's air induction. I thought the cog system still uses a belt lower down?
My D1X has had no belt slip issue and I'm working to max out all my new Lingenfelter stuff, so it has to be working...
01-27-2019, 10:48 PM | #14 |
Drives: 2018 Camaro 2SS, Hyper Blue Join Date: Jun 2016
I did the LT4 conversion on my 2018 2SS and it has worked out great. Stock looking, great power, and has been extremely reliable. 15k miles on the conversion and not one issue. Spent alot of time tuning it, which might be why it's so reliable. Then again, others with the conversion don't post about problems.
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback) 1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk |
