12-21-2017, 08:29 AM | #1 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Wideband Oxygen Sensor Gauge
Hey guys,
Doing a little planning ahead and want to avoid an LT-4 paper weight. 1. What is everyone doing for wideband gauges? 2. Does the LT4 have wideband O2's from the factory?
12-21-2017, 09:26 AM | #2 |
Drives: ZL1/335i Join Date: Apr 2014
No, GM still isn’t using factory widebands. Wish they were. I plan to install one myself for tuning and monitoring, but I’m not sure how critical it really is on a mildly modified LT4. I’ve always watched my widebands like a hawk in my stock bottom end / forced induction LS builds, but this motor is a different animal. I don’t think very many owners here are using one.
12-21-2017, 09:53 AM | #3 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
If you’re interested in getting one, I stock the ECM AFX2. It’s what Ballenger sells without being relabeled. ECM makes the equipment all the OEMs use.
It pairs well with the HP Tuners nGauge. |
12-21-2017, 10:46 AM | #4 |
aka BeastZL1
I'm just following my playbook on my Cobra.
1. Wideband 1st 2. Pulley 2nd 3. I found that a lot of "dyno" tunes end up with lean throttle tip in and lean spots at heavy (50-90%) throttle positions. You're in boost, but maybe not enough throttle to trip the "WOT" fuel tables. Everything looks spiffy on a dynojet, but you lean out during certain conditions on the street, like feathering the throttle all the way through first gear or a highway on-ramp. Questions: 1. Is there a perference on which bank to install the wideband? Does one bank run leaner than the other? 2. Is there a good website or forum for the Ntuner gauge? The NTuner Website looks like it was designed in 1996. 3. Can you hook up a laptop to the Ntuner for datalogging?
12-21-2017, 10:53 AM | #5 |
Are you referring to the nGauge? Unfortunately it cannot flash 17+ Camaros. You’d need full HP Tuners for that.
12-21-2017, 11:10 AM | #6 |
Drives: none Join Date: Nov 2012
I have always had good luck with the PLX stuff. They have something that works for every situation. They can typically tie into their own gauge, other gauges, computers, phones, etc... They use genuine Bosch A/F sensors too.
12-21-2017, 04:38 PM | #7 |
Drives: 69 Z28, 2018 ZL1 1LE Join Date: Jul 2017
This one: http://www.aemelectronics.com/?q=pro...and-uego-OBDII
CAN-bus integration and validated to work with EFILive, HPTuners and DashDaq software. you need a bung installed pre-cat on the passenger side manifold for the 02 sensor. |
12-21-2017, 06:20 PM | #8 | |
aka BeastZL1
Thanks. I didn't know this existed.
12-22-2017, 11:28 AM | #9 | |
Drives: 2018 ZL1 Join Date: Oct 2011
2018 ZL1…Many mods to come
12-22-2017, 07:34 PM | #10 | |
And I’d take any advice Dave (DSX Tuning) gives you. Dude is the best GM tuner I’ve ever come across. |
12-22-2017, 09:48 PM | #11 |
aka BeastZL1
The automotive basics don't change from vehicle to vehicle. I know a lot of people don't think it is necessary, but they are probably living in ignorant bliss.
Things like fuel pump volume change over time or that mineshaft air day pegs your mass-air-flow meter. Do LT4's have MAF's? I'm used to 25 years of Ford systems with MAF transfer tables and multipliers. Does someone have a website or forum they can recommend on GM tuning? The best tunes on my Cobra were mail order tunes with tweaking from data logging on the street and the track. I've got a flat 11.5 - 11.7 AFR regardless of what is happening. There is a red warning light that comes on if AFR is above 12.2 at wide open throttle, so I know to lift. I got used to looking at my injector duty cycles and fuel pump duty cycles on all my drag runs. Is the ZL1 fuel system non-return?
12-23-2017, 08:47 AM | #12 | |
These vehicles use a MAF combined with speed density to operate in what GM calls "dynamic airflow" mode. The MAF is the primary measurement device, but the speed density side is used as both a sanity check and also an assistant with transient conditions. Being DI, you won't want to use traditional fueling ratios in power enrichment though... 11.5 (or 0.78 lambda) would be way too rich. The ZL1 fuel system is returnless. There is a low side pump feeding a high side pump, just like a diesel. |
12-23-2017, 09:58 AM | #13 | |
aka BeastZL1
Thanks for the information. Why would 11.5 be too rich measured at the header? I'm used to 11.5 - 11.9 for forced induction and 13.3 - 13.5 for naturally aspirated engines regardless of configuration.
12-23-2017, 10:57 AM | #14 |
Direct injection is a completely different ball game when it comes to optimal fueling. You'll find that you'd be way down on power at that ratio. LS stuff likes to be about .78-.80 lambda boosted and somewhere around .84-.86 NA, but LTx stuff is way different!
