09-30-2019, 11:21 AM | #15 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
The things mfg'ers do to differentiate between trim levels is ridiculous. Like the bare plastic knee pads in the 1SS, they intentionally make the car look like an econo model vs the 2SS but it only saves them something like $20.
09-30-2019, 05:14 PM | #16 |
With the skirts installed do they reduce the clearance for a floor jack?
09-30-2019, 05:48 PM | #17 | |
Drives: Chevrolet Tahoe, camaro ss1le Join Date: Jul 2019
09-30-2019, 05:51 PM | #18 | |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
So the answer is yes, but only by the thickness on the rocker material. |
09-30-2019, 11:12 PM | #19 |
Drives: 18' 2SS 1LE, 94' Z28 Join Date: Apr 2010
I am running ZL1 skirts with GM rock guards. I will share some pics here soon. Gonna grab some fall pics.
2018 2SS 1LE -
D-1XH Procharged, Pray Tuned, Stainless Works, Anderson Composites, 13GFab, BC Forged & More 1994 Z28 - Direct Port Nitrous - Multi Magazine Feature Camaro Z28 |
10-01-2019, 12:17 AM | #20 |
Drives: 2SS 1LE Join Date: Oct 2011
Not the vertical, but the horizontal, which makes getting the pucks in there a little harder, assuming you have a low-profile floor jack. I can still change wheels myself, it's not the end of the world, but it makes it a little challenging for sure. On a scale of 1-10 I give it 1-2 for an experienced mechanic, 3-4 for a barely-knows-a-wrench mechanic. Not terribly hard or complicated, take your time and make sure you are using a low-pro jack. 10 was changing out steering bushings on my subaru, freaking impossible space to work with...
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
10-01-2019, 10:28 AM | #21 |
Drives: SS 1LE Join Date: Oct 2017
Between the "nice ZL1 comments" and the Mustang GTs that pull up quickly but then drive off quietly when they get a close look at the car, I realize people still confuse it for a ZL1. They may as well have given us the side rockers and the wrapped knee pads lol.
10-01-2019, 01:02 PM | #22 |
Drives: 2020 2SS 1LE Join Date: Jun 2011
How much wider are the front fenders on the ZL1 to the SS? Would it still take the same front nose piece as the SS? I guess I never had them parked side by side to tell. At least it isn't as noticeable to me as say a base C6 to a C6 Z06.
10-18-2019, 11:17 AM | #23 |
Finally got it cleaned up, out in the sun with some better shots of the skirts on it.
10-23-2019, 10:48 PM | #24 |
Drives: 2019 Camaro SS 1LE Join Date: Mar 2019
I got the zl1addons rock guard combines with extremeonlinestore zl1 style side skirts. They mesh perfectly, like tetris pieces. The only problem with the sideskirts is that they are not totally even in length but the naked eye cannot see. same with a small gap but again, the naked eye cannot see. Thew side skirts ran me 218$ usd in primer and i painted them myself. They look good but if you look close and hard you can notice the imperfections
10-24-2019, 10:47 AM | #25 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
I have C7 Carbon's skirts ready to install.
Question to those who already installed theirs: Bolting or riveting requires drilling, correct? If so, to which part is the drilling done on the car? Is it the plastic side under-cover, or is it necessary to actually drill into the frame's metal and bolt/rivet there? |
10-24-2019, 12:54 PM | #26 | |
GM used Rivets in all of the Corvette's and they have a special rivet they use to do it..which was nice to see in the ACS kit. Everything goes into that lower plastic piece, you don't go into any metal when you do it. At least not with ACS. Yes you have to drill it. |
10-24-2019, 01:09 PM | #27 | |
Would be my first choice had it been available back when I ordered mine. I guess that the rivets / screws using the C7 Carbon skirts would also attach to the plastic part and not to the metal frame. Anyone who installed, or knows how it works with C7 Carbon - Post your experience. |
04-20-2020, 03:57 PM | #28 |
IG: @velveteen_camaro
Drives: 2016 Camaro 2SS Convertible Join Date: Dec 2016
Hi, if you posted your pics of the ZL1 sideskirts and GM rock guards elsewhere (another thread?), would you kindly send me the link? Thanks!!
