12-24-2020, 12:30 PM | #1 |
Drives: Chevy camaro SS Join Date: May 2020
what is the best handheld tuner out there
Hello,
I have a 2010 Camaro SS 6.2l, the care is 11 years old and I have the extended warranty on it but after this warranty expires Im not getting another one. I had issues with ENDURANCE(MEPCO) of covering things. But anyway What is the best handheld Tuner out there onthe market for these cars.There is no tuner in my area(location) I asked the dealer to do it. because I put in aftermarket part like new coils, plugs and wires new 3 row aluminum radiator, SS lower radiator pipe and 160 degree thomstat. I also install accent dash lighting and a glove box kit kit. In the Spring i Think i will be installing long tube headers and 3' exhaust system with high flow Cats. I bought the care used with a cold air kit installed and head light changed. The Tuners I was looking at Diablo sport Predator P2 7201 and the Bullydog. Any opinions on which tuner is the best? Thank you in Advance. |
12-24-2020, 01:07 PM | #2 |
Drives: 2010 ss Join Date: Oct 2015
i liked the sct brand.they can be married to 5 different cars or trucks,just not at the same time.also you can shut off the rear o2 sensors,they even came with a header and intake tune.i have a custom tune now.
12-24-2020, 04:39 PM | #3 |
Drives: 2013 L99 Join Date: Jan 2019
Another vote for SCT. Dyno Steve (RDP) is a fantastic guy, ships free and fast, no tax and comes with lifetime custom tunes.
12-29-2020, 04:12 PM | #4 |
Thank you so much for the infomation and pointing me in the right direction. I'll read up on your sugestion. Thanks again.
12-30-2020, 12:30 PM | #5 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
This thread should be called "What handheld did you buy before you got smart and switched HPT?"
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
