10-28-2020, 02:04 PM | #113 | ||
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
As mentioned before, some of you don't understand the difference between TSB and recalls.
As for the cost, I am sure Subaru and Mazda are definitely happy about replacing all the valve springs in their engines(in Mazda's case, it's their diesel engines only so it doesn't impact North Americans). That's a recall, BTW, not a TSB. Quote:
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
10-28-2020, 03:00 PM | #114 | |
Drives: Fast if no one's looking Join Date: Aug 2019
The valve springs, along with every other component of the engine, aren’t mixed in a random pile today like they were in 1970. They’re sorted and inventoried and traced and tracked from the absolute genesis of their existence to the customers name and address who buys the car. |
10-28-2020, 03:16 PM | #115 | |
If those springs are that easy to trace down, they would have been sorted out and discarded before they make their way into replacement engines. Sent from toaster or something
Current:
10-28-2020, 03:18 PM | #116 | |
Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
10-28-2020, 03:39 PM | #117 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
10-28-2020, 03:46 PM | #118 |
Drives: Chevrolet Camaro SS 2018 Join Date: Jun 2019
Not to speak for him but I work in a factory that produces steel plates, and every step of the way, everything that happens, is logged in computers, so if its ever needed, everything down to the second of every step, every transportation and every treatment can be traced back. You cant even move it without being forced to log it into the system, and I'm sure this is the same in GM factories as well, as well as all other factories belonging to major companies.
10-28-2020, 03:54 PM | #119 | |
10-28-2020, 05:20 PM | #120 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
They also put the finished car on a chassis roller and run it through a variety of tests. You can watch them do this at the Corvette plant (or you could before the suspended tours to switch over to the C8). But that's not going to catch a bad batch of valve springs that takes 200mi to show themselves.
Matt Miller
2020 SS 1LE |
10-28-2020, 06:13 PM | #121 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
Really not my line of work. Back in the day i would change spark plugs or even make my own wires on my 1972 Bel air Chevy i called the green lean machine. At least back then you had room to get a hand down and around the engine and know what is what. That was my first car in 1982. That old car ran pretty good for a 4 door.
10-28-2020, 06:17 PM | #122 | |
10-28-2020, 06:20 PM | #123 | |
10-28-2020, 06:26 PM | #124 |
I am just over 160 miles and since i don't drive much it seems like it will take forever for me to get past 500 miles. My vette club stopped all cruises back in June of this year. We would have around 40 vettes out in the country tearing it up. I need to just get somewhere and drive mine without traffic.
10-28-2020, 10:40 PM | #125 |
Hot Camaro
If you're going off of the build sheet, that's the build date for the CAR, though, and only represents the day that the build was started (it takes a couple of days to make it all the way through the assembly process). The engine was likely completed at least a few days to a week prior to the start date for the car. And if you're referring to the general date on the door sticker, that's also referencing the build for the car and not for the engine.
10-29-2020, 02:16 AM | #126 | |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Heck, next you probably say they solder the pistons back together and run the used oil through a coffee filter then pour it back in the motor to save some money too. And, last I checked, the techs are factory trained. Some specialize in certain areas. I had a friend that was a certified tech at a Caddy dealer and all he did was rebuild trannys. I guess somehow they can't train people to rebuild motors because they never ever go bad under warranty, or need to be repaired period and the shop manuals that tell you all the steps to do it are really there for show...
