10-28-2020, 11:01 AM | #85 | |
Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
10-28-2020, 11:05 AM | #86 |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
It seems so far like the springs break within a few hundred miles. Let’s hope after a few thousand miles we are safe from the bad batch of springs.
10-28-2020, 11:07 AM | #87 | |
Hot Camaro
The Takata issue is not limited to Honda, the company went bankrupt, and the sheer number of airbags that need to be replaced put a significant stress on the suppliers to build airbags that could be used as replacements. Honda was been the largest consumer of those airbags, though, and that's why the association is made to Honda specifically. In the end, you can't replace a component if you can't get one from your supplier... So, the delays for the whole process have been awful and rightfully complained about because of the risk to owners/drivers. |
10-28-2020, 11:09 AM | #88 | |
Drives: Fast if no one's looking Join Date: Aug 2019
We can also go back to GM’s ignition switch disaster, which was on the level of Honda’s Takata airbag issue. Big difference though: lots of people at GM knew it was faulty before they even went into production yet pushed them through anyway. Here we have GM knowing the entire batch of valve springs is faulty but refusing to replace them unless and until it causes catastrophic destruction to the engine. |
10-28-2020, 11:09 AM | #89 |
Drives: 2021 Acura RDX SH-AWD Advance Join Date: Aug 2019
The main difference is that when the airbag issue was discovered, they started to recall impacted vehicles and replace the airbags. They didn't say wait until your airbag goes off then come see us.
10-28-2020, 11:10 AM | #90 | |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
10-28-2020, 11:11 AM | #91 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
I had a 2011 Denali, and they recalled its airbag. No replacement was available so the dealer wouldn't offer a fair trade on it--they were concerned about it sitting on the lot too long. I sold it to Carmax for a better price.
10-28-2020, 11:12 AM | #92 | |
10-28-2020, 11:19 AM | #93 | |
If the valve spring issue turns into a recall then yes, GM would be on the hook to replace every valve spring for every affected vehicle. Right now it's not a recall, it's a TSB. If people start getting injured or dying as a result of a bad valve spring we would likely see it become a recall. |
10-28-2020, 11:24 AM | #94 | |
10-28-2020, 11:30 AM | #95 | |
Peace & Progress |
10-28-2020, 11:36 AM | #96 | |
Hot Camaro
If the issue were that GM was installing engines made by a third-party, the comparisons would be much more on par. |
10-28-2020, 12:21 PM | #97 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
I have around 300 miles now. I am going to go for a few rides this weekend and get some more miles and see how it goes.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
10-28-2020, 12:27 PM | #98 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
They don’t need to check every spring, only batches from same wire stock. Somewhere treatment & tensile strength went south. That stuff is tested & recorded at the manufacturer level. Somewhere there is a paper trail on that steel. |
