10-18-2020, 03:20 PM | #1 |
Drives: 1985 Z28 Join Date: Aug 2020
2021 SS 1LE with A10 or 2018 ZL1 A10 ?
2021 SS 1LE with A10 or..... 2018 ZL1 A10 ?
I’m kind of torn between 2 awesome cars and can’t decide. One day I want SS, the next day I’m thinking a used low mile ZL1. Which would you choose and why ? |
10-18-2020, 03:36 PM | #2 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
I already have a 2SS, If I could go back, I'd get the ZL1!!!!! The SS is a GREAT Car, But the POWER of a ZL1 AHHHHHHHH!!!!!!!
10-18-2020, 03:54 PM | #3 |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
ZL1
10-18-2020, 04:23 PM | #4 |
Drives: Camaro SS 1LE Join Date: Aug 2018
200 extra hp, vs track package.
10-18-2020, 04:37 PM | #5 |
Drives: 2019 Camaro 2SS Join Date: Nov 2019
You can track a ZL1 just fine. Go for power.
2019 Camaro 2SS, Shadow Grey
10-18-2020, 04:55 PM | #6 |
LT1_Radenso
Drives: a 2 spd water bottle Join Date: Sep 2017
ZL1 is a no-brainer, 1LE doesn't handle too different from a base SS.
10-18-2020, 04:59 PM | #7 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
If warranty is important, go newer or if you are getting the ZL1 from a dealer & can get a B2B warranty, go that route.
If you honestly feel 455HP is enough, then buy the SS. If you want more now, go ZL1 |
10-18-2020, 05:15 PM | #8 |
Ghost Spawn
Drives: Camaro Join Date: Jan 2019
Which?: ZL1
Why?: For every reason |
10-18-2020, 05:50 PM | #9 |
Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
It depends on your roads and how you drive. If you are doing lots of backroads and are staying 55mph or lower the lighter NA SS1LE will feel about the same speed and is a lighter more balanced car.
If you are driving on roads where you can take advantage of the forced induction then I say go for the ZL1. Also in terms of budget the used ZL1 will still be more expensive, not sure what your budget is. |
10-18-2020, 06:04 PM | #10 |
Hard to want.
10-18-2020, 06:05 PM | #11 |
10-18-2020, 06:12 PM | #12 |
10-18-2020, 06:22 PM | #13 |
Drives: GMC Sierra AT4 Join Date: Jul 2013
OP, what are you looking to achieve with one of these cars in driving? Also question is what are you coming from, says 85 Z28? You are also looking at brand new versus 3 years old used.
2020 GMC Sierra AT4 6.2L
WTB - 2010 Camaro 1SS or 2SS, Aqua Blue Metallic, A6 |
10-18-2020, 06:22 PM | #14 |
Drives: 2SS 1LE Join Date: Oct 2011
The 1LE is the ZL1, minus the supercharger. Same chassis/handling improvements. Slightly smaller brakes because, well, it's lighter. Same size wheels/tires, same magnetic ride, etc. Shifting out of 2nd to third at WOT in the 1LE and you are already going more than 75mph.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
