08-21-2022, 07:14 PM | #43 |
Drives: 2023 Silverado LT Trail Boss Join Date: Apr 2022
Where did you get your 1LE emblems? I was trying to stay away from Chinese made aftermarket ones that are on eBay & Amazon, but it seems like those are the only options. I wish GM offered them as an OEM part
'23 Summit White 1SS 1LE 6MT
4/28/22: 0500 (order placed) 5/10/22: 1100 7/18/22: 2000 Accepted by GM 7/19/22: 3000 Accepted by production control 9/9/22: 3100 Available to Sequence 9/9/22: 3300 Scheduled for Production 9/10/22: 3400 Broadcast TPW: 8/29/22 ---> 9/19/22 ---> NOW 9/26/22 10/4/22: 3800 Produced 10/10/22: 4300 Intermediate Del. - Delivered 11/2 |
08-21-2022, 08:30 PM | #44 | |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
https://wildhammermotorsports.com/16...-s-wildhammer/
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 08-22-2022 at 08:33 AM. |
08-22-2022, 07:55 AM | #45 | |
Thanks!
08-26-2022, 04:31 PM | #46 |
I installed my Mishimoto oil catch can today. This is the third vehicle that I've had one on. Good quality and good fitment. Pretty easy install too. I was able to do the install without removing the center engine cover, but I did have to remove the bolts that hold it on in order to disconnect the stock hose. Being able to lift the front of the cover slightly allows enough access to be able to disconnect the hose.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 08-26-2022 at 08:55 PM. |
08-29-2022, 10:54 AM | #47 |
Received these stealth lift pads from ZL1 Addons today. Very nice aluminum pieces. I plan to install them next weekend. More pictures to come.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 08-29-2022 at 01:09 PM. |
09-05-2022, 10:55 AM | #48 |
Finally got around to installing my ZL1 stealth lift pads. Used my Race Ramps to get the front up in the air. From there it was fairly easy get to both the front and the back.
While under the passenger side of the car I noticed one of the rivets was missing from my ACS side skirt, so I also replaced it. I hadn't checked them since installing them. Checked the drivers side as well and everything looked fine. Probably a good idea to check them periodically.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
09-05-2022, 11:02 AM | #49 |
If you don't have a lift and you do a lot of your own maintenance on your car, I highly recommend a set of Race Ramps. I purchased mine several years ago and use them on all my vehicles. They aren't cheap, but they are very light and super strong. And if you get the two piece versions like mine you can remove the ramp part in order to get under the side of the car.
09-05-2022, 11:24 AM | #50 | |
Drives: 2022 Camaro SS 1LE Join Date: Sep 2011
Mark
Sugar Land TX 2022 VOM Camaro SS 1LE |
09-05-2022, 12:44 PM | #51 | |
https://www.raceramps.com/garage-ser.../p/rr-xt-2/:// Also mine are the heavy duty 2500 pound version rather than the 1500 pound version. I even use them to change the oil in my SUV.
09-05-2022, 01:07 PM | #52 | |
Mark
09-05-2022, 02:52 PM | #53 |
You are welcome! Hopefully you will have your 1LE soon.
It's an awesome car.
09-10-2022, 02:06 PM | #54 |
Hey Z, where is the best place to order ACS Composite ZL1 rails? Just straight from ACS? Also, is that your car on their site?
09-23-2022, 11:54 PM | #55 |
Sorry I just saw your post. I ordered mine straight from ACS. Great customer service.
09-24-2022, 12:02 AM | #56 |
Unfortunately I got the dreaded P00C6 code again today when I attempted to start my car. It had been sitting for 5 days. This is the third CEL I've gotten for the same issue since I've owned the car. The code is for insufficient fuel pressure in the fuel rails.
The first time it happened I took it to my local dealer to have it checked out, but although the saw the code the could not duplicate the issue. I'm going to try to take it back to them to look at again next week, but I'm not optimistic that they are going to find anything different. I've posted about this issue several times after finding one 2018 thread where someone else got the same code, but no one else seems to have had this issue.
