dave@hennessey
Old 10-16-2019, 06:22 AM   #1
snake309
Drives: 2011 Camaro SS, 1985 Iroc Camaro
Motor Mount Bracket Question
Has anyone used any other kind of motor mount brackets other than stock ones? The reason I ask is I have a set of G8 brackets at home that I was thinking of using but I don't know if the specs are the same. With the Gm strike going on I'm having a hard time ordering the correct ones
snake309 is offline   Reply With Quote
Old 10-16-2019, 11:41 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Well, the part numbers are totally different which isn't a good sign. GM will tend to use the same part on multiple models when possible to save design and manufacture costs, so if it has a different part number it is likely a different design. I would hate to see you get the engine nearly in but discover the engine is a few inches too far or close the the bellhousing.
Camaro: L - 22805661, R - 22843611
G8: L - 92290251, R - 92160952
InFiD3ViL is offline   Reply With Quote
Old 10-18-2019, 05:31 AM   #3
snake309
Makes sense, I figured it wouldn't be that easy. From what I hear the strike is almost over so hopefully I can get the correct brackets soon
Old 10-18-2019, 10:46 AM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
Line up the 2 mounts side by side and see if they are visually the same or obviously different.
Vegas Bound is offline   Reply With Quote
Old 10-18-2019, 01:14 PM   #5
snake309
I cant get my hands on the original at this time or I would
Old 10-18-2019, 01:26 PM   #6
G8One2
Drives: 2014 Camaro 2SS
Most likely a difference in height and how high or low the engine sits under the hood.
G8One2 is offline   Reply With Quote
