12-21-2016, 09:35 AM | #15 | |
Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
12-21-2016, 10:31 AM | #16 | |
Drives: 17 Camaro 2SS Join Date: Jan 2012
12-21-2016, 11:44 AM | #17 | |
ummmm
Drives: 2016 2SS M6 Nightfall w/Blk Wheels Join Date: Jul 2016
The "feature" is that you won't accidentally be driving around with the e-brake on - but yes, I turn off the e-brake myself instead of "just going" |
12-21-2016, 12:14 PM | #18 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
12-21-2016, 02:55 PM | #19 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
Hold the brake then press up, up, down, down, left, right, left, right, B, A, select, start... works for me every time!
12-21-2016, 07:38 PM | #20 |
Well I suppose I was expecting the car to realize when I depressed the clutch and put it in gear that it was time to release the e-brake. That I have to try to move the car while the e-brake is still engaged strikes me as a flawed implementation of "automatic disengagement."
And I am well aware of the simple button on the console, but there is nothing "automatic" about that, hence my question. |
12-21-2016, 09:16 PM | #21 |
Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
12-21-2016, 10:02 PM | #22 |
Want best solution to this is dont use it lol.. if you park down hill leave the car in first gear same as going up hill. Each time i pick up my car from dealership they dont use it, its left in gear. But if its not working let the dealership know about it.
12-22-2016, 12:51 AM | #23 |
I have an M6 and I have gotten very used to the ebrake. I'm in Florida in a non-hilly area. When I park the car, I pull into a spot or my driveway (forward or back in), keep my foot on the brake, put the car in neutral, and lift up on the ebrake. I then let my foot off the brake and shut off the engine. When I get back in my car, I have my foot on the clutch, start the car, put my foot on the brake, push down on the ebrake, then put it in gear. Sometimes I push down on the ebrake too soon before my foot is on the brake pedal and it beeps and warns me that I need to have my foot on the brake if I want to manually release the ebrake. Sometimes I just put it in gear and go. I feel a slight hesitation until the ebrake automatically disengages.
There are a couple of slight hills in town and I have tested the scenario of having the car in N or 1st with my foot on the clutch and brake and engaging the ebrake. I then remove my foot from the brake. When the light turns green I put it in 1st (if not already) and give it some gas while releasing the clutch. Again, a slight hesitation but then the ebrake disengages automatically. I like not having to sit at the light and balance the clutch/gas to hold steady, or jump from the brake to clutch/gas and slightly roll back. The only problem people have pointed out is that my brake lights are not on if my foot isn't on the brake, so someone could hit me from behind not realizing I'm stopped. I don't know if that would be my fault, but it is something to think about. All-in-all, the ebrake is well designed. Since I haven't driven a manual in years, I don't have an issue reaching for the parking brake, or have a sense of the ebrake not seeming adequate vs pulling on a handle.
2017 50th Anniversary Edition 2LT V6 6-spd Manual - Order TQHKNZ
Received VIN 08/23/16: 1G1FC1RS2H0127445 Dennis Vaughan @ Schumacher Chevrolet in Lake Park, FL 1100 - 07/09/16 | 9000 - 07/22/16 - Order Cancelled from Stingray Chevrolet 1100 - 07/24/16 | 2000 - 08/02/16 3000 - 08/03/16 | 3100 - 08/08/16 - TPW 8/22/16 3300 - 08/10/16 | 3400 - 08/11/16 3800 - 08/23/16 | 4200 - 08/29/16 4800 - 09/03/16 | 5000 - 09/07/16 6000 - 09/10/16 2013 2LS Build Page: 2 THE CAVE... I'm Batman! 2LS Blackout 2013 2LT/RS Build Page: The Evolution of Iron Man |
12-22-2016, 05:45 AM | #24 |
Drives: 17 SS 1LE Join Date: Dec 2015
I just use it like a traditional parking brake. Foot on the brake pedal + pull up to activate, brake pedal + push down to deactivate.
Wish it had a mechanical handbrake instead. |
12-22-2016, 08:21 AM | #25 |
I figured out my problem with the "automatic" operation... the controlling logic has to see at least a foot tap on the brake before it will release.
So, start car with parking brake on, clutch depressed, put it in gear, release clutch... NO GO! Start car, clutch depressed, put it in gear, TAP BRAKE, release clutch and go. Even though the parking brake is engaged you have to hit the brake pedal. |
12-22-2016, 09:34 AM | #26 | |
Drives: 2ss Nightfall Grey Join Date: Dec 2016
12-22-2016, 11:18 AM | #27 | |
12-22-2016, 03:44 PM | #28 |
Drives: 2016 2SS Camaro fully loaded. Join Date: Nov 2016
You guys complain too much lol. I too always used a manual hand brake, even in my automatic cars. it's always a good habit IMO.
It's taken me a while to get used to the electronic one but honestly I love it. It's more out of the way and the automatic release is great for long duration hill stops.
