06-24-2018, 04:21 PM | #1 |
Drives: 2018 ZL1 1LE NGM Join Date: Dec 2017
Anyone have luck with an aftermarket shifter?
I have about 550 miles on my zl1 1le and absolutely hate the vague, rubbery feel of the shifter. The throw length isnt too bad, but the 4 to 5 shift is driving me nuts with all the slop...
Anyone have any luck with the aftermarket? Or maybe swap bushings for a stiffer material like delrin or bronze? Noise/vibration arent a concern for me... i would take an increase in NVH if i could get a solid, positive feel out of the shifter. Additional thoughts/concerns: Im not familiar with the internals of the tr-6060, but i do know i needed a shifter with positive stops in a mustang i built using an early t-56. The first solid shift in that trans blew out the plastic cup shaped bushing the shifter sat in. Replaced the plastic cup with a bronze bushing and promptly destroyed the synchros when i blew through the internal stops the next time i tried to shift quickly. I would prefer to not have that happen again. Thanks! |
06-24-2018, 09:55 PM | #2 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
I’ve wondered the same, I know mgw is not making one for our cars
06-25-2018, 12:16 AM | #3 |
Aftermarket shifter
What about Hurst?
06-25-2018, 03:01 AM | #4 |
Dont know... waiting on an email... mgw was kind enough to reply on the weekend with the following:
I am sorry but we actually did have a gen 6 camaro in-house for about 6 months working on a shifter but ended up scrapping the project due to the tight tunnel clearances to make a proper shifter. Im tempted to get a replacement 1le shifter (so my car isnt down since its my daily) to tear apart and figure out if i can just replace all the bushings with a more solid solution instead of rubber and see if that works. |
06-25-2018, 04:34 AM | #5 |
Drives: Really Fast Join Date: Aug 2017
Of course everyone is entitled to their own opinions. It’s my opinion that the shifter in the Camaro is outstandingly good. I’ve had a Hurst in a previous car and understand what you mean with regard to the rubber OEM bushings but the OEM shifter is one of the best I’ve rowed gears with. Perhaps it’s your style? I’ve noticed with manual transmisions that less effort gets you better results.
THIS SPACE FOR RENT
06-25-2018, 05:17 AM | #6 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I don't know how a shifter can get much better than what the ZL1 1LE comes with !!
You would despise the shifter in my challenger hellcat. hahahaha
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
06-25-2018, 06:39 AM | #7 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I looked into this one prior to getting my 2018 ZL1: https://www.phastekperformance.com/2...er-3916031.htm
But after I got the car, I decided against it. My only complaint with the car was the shift knob and I solved that with a Barton adapter and an Epco knob...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
06-25-2018, 11:29 AM | #8 | ||
Drives: 2022 ZL1 1LE Join Date: Sep 2015
I have to agree with both of the above quotes. I had a 2013 Boss 302 with a very crappy trans/shifter. Then my '15 Z/28, which was quite decent for a stock shifter. IMO, the trans and shifter for my Z/LE is about the best I've felt on a factory manual trans in many years. In addition, I love the ratios in the 6060 in the Z/LE....a true close ratio box with fantastic gear spacing. Once I got used to the tension in the shift gates, I found it to be very well done for a factory shifter. I never felt the need to change the feel of it. JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!! 2021 F-250 FX4 2023 Hyundai SF Calligraphy |
06-25-2018, 12:53 PM | #9 | |
Thank you all for the replies, ill probably buy the gm short shifter to tear apart and see if bushings will tighten up the feel (only cause i cant afford to have the car down since its my daily). If i come up with anything ill let you guys know. Peter |
06-25-2018, 01:21 PM | #10 |
Drives: 2018 Camaro ZL1 (A10) Join Date: Apr 2017
Definitely NVH management. The stock shifter in my GT350 was a rattle trap, even though it shifted reasonably well. I replaced it with an MGW, which completely eliminated the rattle, shifted extremely precisely, but had crazy resistance. I almost needed to start doing extra reps at the gym with my left arm because the shifter was making my right arm bigger. Lol
2018 ZL1 A10 | Roto-Fab CAI | Mamo Ported TB | HRE FF04 | Michelin PS4S 285/305
06-25-2018, 03:42 PM | #11 |
Drives: 2018 Camaro ZL1 1LE (Black) Join Date: Jan 2018
I second that^^^, Challenger shifter was terrible!
05-20-2021, 05:18 PM | #12 | |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
05-20-2021, 06:39 PM | #13 | |
Have had mine for almost 3 years now. Works great.
05-21-2021, 06:04 AM | #14 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2019
I think the shifter in the ZL1 is excellent as well. I have been driving a stick for many years...
my only complaint is second gear... that is a royal PIA.
2018 ZL1 - Daily driver
2018 Mercedes Benz AMG GTS 2017 C7 Grand Sport - Stage two Edelbrock |
Thread Tools | |
