Old 06-18-2018, 08:54 PM   #1
gosutag
Left Lane Enforcer
Drives: '18 ZL1 1LE.
ZL1 1LE 18" 325 square setup?
anyone running something similar? Do 18s fit over the 6piston brakes? What am i looking at in terms of drivability? Any opinions?
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
2014 Chevy Malibu LTZ
gosutag is offline   Reply With Quote
Old 06-18-2018, 09:17 PM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
I don’t think a 325 would fit square (on all 4 corners) certainly not in the front. I’m thinking widest would be 305 in the front.
Markoz28 is offline   Reply With Quote
Old 06-18-2018, 09:46 PM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
an ungodly amount of groove steer, with tires that wide in the front.
Old 06-18-2018, 09:52 PM   #4
full*throttle*therapy
Drives: '18 RH ZL1 1LE
why would you want to go that wide up front? to mitigate understeer? are you experiencing some behavior in the car at the limit that would suggest you require a wider tire up front? Have you exhausted all camber/toe/height/swaybar options to dial out your issue?
full*throttle*therapy is offline   Reply With Quote
Old 06-18-2018, 11:43 PM   #5
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Bigger is not always better as they say
Old 06-19-2018, 07:40 AM   #6
gosutag
Left Lane Enforcer
I meant a 315 square setup. I was aiming at a thinner rear setup. And wondered subsequently if 315s up front would even be possible. I was wondering what it would do with the suggested track settings. I'm wondering for economic reasons to see if it would be worth it to go square performance wise that would make saving money on tires worth it. Would 18s fit around the brakes?
Current Cars:
2018 Camaro ZL1 1LE
2012 Ford Focus SE
1994 Evo II
Previous Cars:
2017 Camaro SS
Old 06-21-2018, 09:35 PM   #7
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
There is defiantly room for a 315 up front, I have room with the stock 305's even with 3* of camber. I'm kind of planning on a 325 and 345 Hoosier A7 set once the stock goodyears are gone for autocross
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 06-24-2018, 09:57 PM   #8
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
325 fronts (325 PSC2 in my case) rub on the lower spring mount on OE ZL1 1LE wheels.
Provoste is offline   Reply With Quote
Old 06-28-2018, 10:43 PM   #9
tomster
RedLine
tomster's Avatar
Drives: 2022 ZL1 1LE
I run 325 square . front tire is very close to the spring perch but it does clear no rubbing.. My front is also set all the way low and I run -3 camber up front. If it were to rub you could pull a little camber out at the spindle. (FYI) If you don't have ZL1 1LE front struts i dont think it will work the spring perch is smaller
Also i haven't seen anyone fit 18's up front
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold)
2018 CTS-V "Black" (Sold)
2022 GMC 2500 "Blue"
2022 ZL1 1LE 6spd "Rapid Blue"
2023 ZL1 1LE Auto Rapid Blue (ordered)
tomster is offline   Reply With Quote
Old 06-28-2018, 10:47 PM   #10
Provoste
Provoste's Avatar
Originally Posted by tomster View Post
I run 325 square . front tire is very close to the spring perch but it does clear no rubbing.. My front is also set all the way low and I run -3 camber up front. If it were to rub you could pull a little camaro out at the spindle
-3.25 front camber is where I was getting rub. Lowered front, not all the way down.
