11-13-2010, 10:21 AM | #1 |
Drives: Me 2001 F150, The wife '11 2SS RS Join Date: Aug 2010
Change your differential fluid!
We just hit 1,500 miles on the car and since the manual recommends changing the differential fluid at this point I did it last night. And I am astounded by how much metal was in it!
It looked like liquid metal pouring out with a fair amount of little shards stuck to the magnets in the plugs. If you haven't changed it I would highly recommend you do it. I'm personally going to change it again at the next oil change. |
11-13-2010, 10:35 AM | #2 |
Drives: '69 SS Convertible Join Date: May 2009
+1
And use synthetic going back in. I used Royal Purple. I've already done both Trans Oil and Rear End Oil.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
11-13-2010, 10:55 AM | #3 |
How hard is it to change the manual says a dealer has to do it and Lord that would cost a fortune!
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
11-13-2010, 11:18 AM | #4 |
11-13-2010, 11:23 AM | #5 | |
Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
Your Differential only takes one quart.
Also I pay $70 for the 8 quart synthetic mobil 1 oils change at the dealer. Don't let yours rip you off on that either. Here is a link for some differential fluid info. http://www.camaro5.com/forums/showthread.php?t=76160
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128 Northern Massachusetts & Southern New Hampshire Camaro Club http://www.camaro5.com/forums/group.php?groupid=127 The mother of all supercharger questions thread http://www.camaro5.com/forums/showthread.php?t=77958 My 2010 Camaro Review http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442 2010 Transformer Edition Camaro L99 Auto |
11-13-2010, 11:24 AM | #6 |
Drives: '11 2SS/RS L99, '12 2LS LFX Join Date: Jul 2010
You got any pics of the metal shavings?
11-13-2010, 11:31 AM | #7 |
11-13-2010, 11:37 AM | #8 |
I would say it was comparable to this random pic I found with google
This pic doesn't really do it justice of how bad it really looks but its an idea considering clean gear lube looks like clean motor oil It looked like mercury pouring into the can I was catching it in |
11-13-2010, 11:46 AM | #9 |
Drives: 2011 2LT - 73 Corvette 454 Join Date: Sep 2010
Would somebody please tell me where in the manuals there is a recommendation to change differential fluid. I've read through the 2011 owners manual, supplimentals, and warrante manual and have only found one reference to the differential fluid at all, and that was saying how much fluid the differential holds. That reference is on page 12-3. The rear end takes 1 quart by the way.
In secition 11, starting on 11-2 all scheduled maintenance required is outlined. I don't find any reference to rear end fluid changes or manual transmission fluid changes in that section at all. Further, on page 10-14 you will find this section titled: Manual Transmission Fluid |
11-13-2010, 11:47 AM | #10 |
Drives: 2010 white SS Join Date: May 2010
I hope this isn't the reason my rear end feels like it's going out.... I haven't changed it and it has 7500 miles on it.
11-13-2010, 11:48 AM | #11 | |
11-13-2010, 11:58 AM | #12 |
Dances With Mustangs
If anyone hasn't changed it already, change it now. I highly recommend Royal Purple Maxgear 75w90 gear oil. 1 qt will make a noticeable difference.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
11-13-2010, 12:01 PM | #13 |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
Competitively is a whole lot different then normal driving. That was referring to road racing.
I ended up changing ratio to 3:70. Part of Lingenfelter mods. I'm a little surprised at the amount of metal you are talking about though. Need a mechanic input to see if its normal.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
11-13-2010, 12:09 PM | #14 | |
New Vehicle Break-In Notice: Follow these guildelines during the first 2415km/1,500 miles of driving this vehicle. Parts have a break-in period and performance will be better in the long run.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
V6 M6 transmission fluid change help | camaro guy | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 8 | 05-14-2012 06:55 AM |
rear differential fluid drain/fill plug location | Dentyneice | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 9 | 11-27-2010 10:54 PM |
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! | Apex Motorsports | Transmission / Driveline | 28 | 11-27-2010 10:46 AM |
I want to change rear diff and tranny fluid.?? | The Enforcer | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 6 | 04-06-2010 03:11 PM |
