04-28-2023, 07:50 PM | #71 |
Drives: 2021 Camaro ZL1 Join Date: Mar 2023
Good read.
I have been planning out my next mods and thought I was set on doing a BTR stage 1 or 2 Cam next so I could take more advantage of more Ethanol content, and then do an X-port. But now I am thinking of switching that around and doing the X-port first, and then the cam.... I had previously thought I wouldn't be able to run much Ethanol content at all, but this certainly shows it still capable of a good amount of E if doing the X-port first. The X-port is cheaper (if not doing self install) and definitely much easier. I'm thinking the X-port would probably gain a little more HP too.
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, Atturo 315 AZ850DR |
04-29-2023, 05:45 AM | #72 | |
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, and Elite E-2X catch can. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
04-29-2023, 08:54 AM | #73 |
Drives: 98 Camaro Join Date: Apr 2022
I see everyone doing the X port now
04-29-2023, 09:15 AM | #74 |
That's because it transforms the stock unit into a completely different animal. It goes from being peak efficiency @10-11psi to 14-15psi with very little heat increase.
2016 NFG 1SS A8
04-29-2023, 09:52 AM | #75 |
04-29-2023, 06:03 PM | #76 |
Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Can somebody explain why is used epoxy on x-port? I have read something about it and problems due to this…
Thank you.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
04-29-2023, 07:22 PM | #77 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Where have you read about problems due to the epoxy used? I'm aware of one source but that source is also a competitor to Kong and really hates Kong.
04-29-2023, 08:52 PM | #78 |
The use of epoxy wouldn’t surprise me at all, and I don’t mean that negatively at all. I know radical port jobs on the LSA required porting through the casting and then welding up the holes that resulted. To get the kind of big airflow improvements the X-port gets out of a tiny 1740 blower…you’re gonna need to break some eggs to make that omelette.
04-29-2023, 09:38 PM | #79 |
Jokers full tilt doesn't use epoxy. I am not saying epoxy is a issue. A lot of X ports out there seem to be doing fine.
2016 NFG 1SS A8
04-30-2023, 05:13 AM | #80 |
04-30-2023, 06:13 AM | #81 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
No issues whatsoever with my X ported little guy and it absolutely screams. As mentioned above the car is a completely different animal with it (and I’m on stock pulleys).
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
04-30-2023, 09:51 AM | #82 |
Have you gotten to tune any cars with Joker port jobs? I know they have a good reputation too, but curious how big of a difference there is in either direction. Seems to be less reviews of Joker ports.
04-30-2023, 10:35 AM | #83 |
No unfortunately not. Every car I have done has been a Kong port. I know Justin Keith and Pray Performance use Jokers. Any kind of decent port program really helps the stock blower regardless. If I bought a ZL1, ported blower and flex sensor would be the first 2 mods.
2016 NFG 1SS A8
04-30-2023, 11:08 AM | #84 |
Pretty sure he used epoxy in porting mine. [no, he didn't]
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 04-30-2023 at 11:35 AM. |
