02-10-2020, 09:39 AM | #1 |
Drives: 2021 Camaro LT1 Convertible Join Date: Apr 2019
2020 Camaro LT1
I have the 2020 Camaro LT1 with NPP Dual mode exhaust. What is the cheapest way to make it a little louder? I love the sound of the chargers and mustangs, i feel they are a little more aggressive than the stock camaro exhaust
02-10-2020, 09:45 AM | #2 |
Pull fuse 51 and set the exhaust in Track mode in the DIC settings! Check to make sure that 51 controls the NPP exhaust like in the 2016-2019s.
02-10-2020, 10:15 AM | #3 |
I assume there is a way to "un do" it afterwards if needed? the car is a lease, just want to make sure i'm not doing anything that'll affect that
02-10-2020, 11:21 AM | #4 |
Drives: 2017 Camaro SS Join Date: Mar 2016
All you have to do is put the fuse back in.
2017 SS manual ordered through the one and only Becky!
For sale: https://www.camaro6.com/forums/showthread.php?t=612154 |
02-10-2020, 11:36 AM | #5 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
So no “Track Mode” that was a deal breaker for me. https://youtu.be/HPK6N1mKcck 7:50 mark
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 02-10-2020 at 11:52 AM. |
02-10-2020, 11:46 AM | #6 |
Yes I knew that he was talking about the LT1 and not the SS! That’s why I suggested he check it out first before doing the fuse pull!
02-10-2020, 11:50 AM | #7 |
02-10-2020, 11:54 AM | #8 |
I have no idea! Sorry! Maybe some 2020 owners can chime in!
02-10-2020, 02:15 PM | #9 |
Drives: 16 1SS M6 Black -previous 00 Z28 M6 Join Date: Oct 2018
Flip down the back seat for increased interior rumble.
02-10-2020, 02:42 PM | #10 |
No...all pulling the fuse does is remove power to the NPP valve controllers. They are set to Open by default and close after startup depending on the performance mode. So pulling the fuse keeps the valves open under all conditions.
2016 NFG 1SS A8
02-10-2020, 02:48 PM | #11 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
No need to set to track mode if the fuse is pulled.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
02-10-2020, 02:54 PM | #12 |
I pulled the fuse in my ZL1 and set the exhaust to Track mode and it really didn’t seem to make much of a difference in sound so I put it back in and set the exhaust to Auto mode!
02-10-2020, 03:41 PM | #13 | |
Drives: 2016 SS Join Date: Oct 2019
I pulled the fuse on mine, and also found it to be about the same as track mode. ....that being said, if the OP doesn't have a track mode....I imagine the fuse pull would yield at least some difference. Either way, I still found it to be pretty darn quiet. Installed an AWE touring system just this past weekend! |
02-10-2020, 04:11 PM | #14 |
Kyrac
Drives: 2018 2SS A8 Join Date: Feb 2015
I did the fuse pull in my 18 SS almost immediately after buying the car because exhaust was too quiet... Still wasn't quite as loud as I wanted, I want to HEAR that V8 rumble so like 'Abubaca' I installed a MBRP axle-back exhaust over the weekend (which is basically straight pipes) and can't wait to actually get the car out on road to hear it now!!! Only another month or two, gotta love OH!!!
