04-17-2019, 09:05 PM | #1 |
SS
Drives: 2018 ss Join Date: Mar 2018
Sometimes i can't rev while on N
On the A8 whenever i rev while on the streets i put it on N rev than back on D . and make sure the gear changes before i hit the gas of course but why is it sometimes when i put it on N i can't rev typically when im slowing down or lower speeds?? Thanks in advance excuse noob question lol
04-17-2019, 09:58 PM | #2 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
I think it's by design. I'll let the auto people answer.
04-17-2019, 10:42 PM | #3 |
Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
I've only reved in n between 30-65. Works everytime.
04-17-2019, 11:21 PM | #4 | |
Drives: 2017 Super Sport Cam. Join Date: Feb 2018
Can't Rev!? WTF? |
04-18-2019, 05:44 AM | #5 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
I've noticed this as well in the M6. If you're coasting to a stop in neutral and you try to rev nothing happens. But once you stop you can rev.
Sent from my iPhone using Tapatalk |
04-18-2019, 10:25 AM | #6 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Never noticed because I don't do it. Back in the day, unsure if true or not but you could cause excessive wear on bearings and rings due to piston slap. A piston not under load and freewheeling is not good for the rotating assembly. Unsure if this is true now with better engine tolerances.
04-18-2019, 11:10 AM | #7 | |
Drives: 16 1SS M6 Black -previous 00 Z28 M6 Join Date: Oct 2018
Yeah the electronic throttle throws you off a bit - you have to completely floor it to get it to rev in that case, but that's excessive. Because of this I always use rev-match. I've tried running without it but the inability to know when the throttle will or won't respond how you expect makes it very tough to downshift smoothly. |
04-18-2019, 11:22 AM | #8 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
I don't know why anyone would throw it in N while driving and rev it, so I can't speak to that, but I have revved it in park to try to isolate a noise, and it revs slowly unless you give it half throttle or more. But it revs. I'd imagine it's a safety feature to keep people from bouncing off the limiter on accident when reaching for luggage in the back seat or something.
