04-12-2019, 08:58 AM | #1 |
Drives: 2018 Camaro 2SS Redline Join Date: Mar 2019
Z26 pads and break in procedure
Not sure I can do the break in procedure in my neighborhood. 40 mph might piss off my neighbors. LOL
Has anyone skipped it or did a partial break in with good results? |
04-12-2019, 09:18 AM | #2 |
You're supposed to do several 60 to 30 and 60 to 15 runs, so 40 mph isn't even going to cut it. Last time I did mine I went to a four lane road with little traffic, very early in the morning, hogging the right lane for a couple miles with my hazards on.
I know this doesn't sound overly professional, but that's the only means I was able to conjure up over here, there's way too much traffic everywhere.
04-12-2019, 09:20 AM | #3 |
One of the benefits of living in the country. Country roads and no safety/smog.
04-12-2019, 09:20 AM | #4 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
It's a street pad, it'll break itself in as you drive it just like every other production street car on the planet. Don't worry about it.
04-12-2019, 12:48 PM | #5 | |
Drives: 2017 2SS Join Date: Apr 2016
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
04-12-2019, 01:01 PM | #6 |
Hot Dog
Ok, explain how every mass production car on the planet does its pad break-in. I'll wait for you to continue making a fool out of yourself.
04-12-2019, 01:03 PM | #7 |
Drives: '19 2SS M6. Join Date: Aug 2018
The website states the following. (Google and a minute of reading is a good thing!)
5 moderate to aggressive stops from 40 mph down to 10 mph in rapid succession without letting the brakes cool and do not come to a complete stop. If you’re forced to stop, either shift into neutral or give room in front so you can allow the vehicle to roll slightly while waiting for the light. The rotors will be very hot and holding down the brake pedal will allow the pad to create an imprint on the rotor. This is where the judder can originate from. Then do 5 mod*erate stops from 35 mph to 5 mph in rapid succession without letting the brakes cool. You should expect to smell some resin as the brakes get hot.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
04-12-2019, 01:11 PM | #8 | |
Hot Dog
04-12-2019, 01:40 PM | #9 | |
Maybe I missed it? Show me something different. All high performance pads need some type of break in. Regular car pads can get by with the grandma treatment if all you do is get groceries.
04-12-2019, 01:46 PM | #10 |
04-12-2019, 01:48 PM | #11 | |
Drives: A few Join Date: Oct 2017
For general use pad break in really is pointless. Just don't abuse them for a couple hundred miles and you'l be fine.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
04-12-2019, 02:40 PM | #12 |
Ok, I'll move to the country for my brake in. LOL
04-12-2019, 03:51 PM | #13 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
On the stock pads, they're much more likely to squeak if you don't burnish.
I have Z26 and didn't bother to burnish and so far no problems but I don't see the harm in following Powerstop's recs, hard stops from 40 mph isn't that hard to accomplish. Will it make a difference? Maybe, maybe not... I'll put the stock pads back in for track use anyways. |
04-14-2019, 08:55 PM | #14 |
Ryephile, thanks for the PM reminder that I was tasked with responding to you. I was busy doing a brake job where I just finished the fluid flush and brake burnishing procedure today.
I will reiterate some of the information that is already available from the engineers who design, validate, and support the use of brake systems. The burnishing procedure recommended at the beginning of the pad life serves to control the phenomenon at play which is the act of burnishing. Through friction and the heat generated by it, the compounds in the brake pad and rotor will infuse. The procedures described are an attempt to burnish the materials together evenly, creating a surface that will resist the negative effects of burnishing. Burnishing has just as many negative effects as it does positive. If allowed to go completely uncontrolled, it can cause cracking, "hot spotting" if the material deposits are drastically uneven, and objectively annoying things regarding performance of brakes. All brake systems are designed to overcome the full power available of the vehicle. Some cars have 180 lb ft of torque, 455, or 650. They must also dissipate the energy of the vehicle in motion. It is all dissipated as heat. High performance brakes are more susceptible to improper burnishing because they are potentially tasked with higher loads. One might find that their Chevy Cruze has no discernible issues with brakes despite not completing a controlled burnishing procedure. But their brakes are unlikely to see the thermal loads required of a Camaro or Corvette. There are more objective, evidence based reasons to follow the burnishing procedure for high performance brakes than there are naysayers who cannot be bothered to follow simple instructions. I prefer to follow instructions of the engineers who design, validate, and support these systems because I am one of them.
Thread Tools | |
