04-10-2019, 08:06 AM | #15 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Apr 2019
04-10-2019, 08:15 AM | #16 |
Drives: 1SS 1LE Join Date: Mar 2018
Im on the all seasons bridgestones RE908AS and its very streetable for me, stock tire size. Then again I loved the stock tires also.
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
04-10-2019, 05:53 PM | #17 | |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Some may want a square setup for all out race ability, but it doesn't look like that's what OP is asking for.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-11-2019, 09:48 AM | #18 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I would wonder if a square set up is faster on track than the OEM staggered set up. I would only want a square set up ( which I do) for the ability to rotate and get more miles and less noise out of the tires.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
04-11-2019, 10:16 AM | #19 |
Will the rear 1LE wheels fit up front let's say you went to a 285/35 tire for a square set up. and would the rear wheel look funny on the front, with the offset and width...?
I ask from the Mustang GT/PP I had...you couldn't put the rear on the front w/o a 5mm spacer due to the differing offset or it would rub. |
04-11-2019, 11:16 AM | #20 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
For summer/street I'd stick with the stock tire size, it's what the car was designed for and while it may be overkill it's not that much more expensive as larger tires have come way down in price over the years. Also, it's possible running different wheel sizes with or without spacers may effect your warranty so you may want to check with your dealer. |
04-17-2019, 10:33 AM | #21 |
Drives: 2009 Pontiac G8 Join Date: Sep 2018
With a 20x10F and 20x11R setup I would consider 295/30/20s in either Pilot Sport 4S, or Continental ExtremeContact Sports. both offer good grip for when you want to have fun, and are excellent at clearing water. They offer good tire life for their performance, and 295's front and rear allow you the option to swap tires front to back occasionally for increased tire life. It's a little bit of a tight fit up front, but should be doable.
