04-06-2019, 04:29 PM | #1 |
20x10 20x12 on 1SS - NO MRC
I'm looking at the set up below but I'm not sure if there will be any rear fitment issues:
20x10 front on 285/30 Continental Extreme Contact Sport 20x12 rear on 305/30 Continental Extreme Contact Sport Car is stock. Suggestions are appreciated. Last edited by C4MSS; 04-10-2019 at 12:33 AM. |
04-06-2019, 06:43 PM | #2 |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
Short answer - it will fit as long as the 20x12 isn't some weird offset (which you'd have to post to be sure)
Curious why you would go to a 12in wheel only to run a 305? Can easily run a 325 with that... Seems like a waste
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
04-06-2019, 10:10 PM | #3 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
04-07-2019, 02:12 AM | #4 |
Your offsets should be fine, so should 325s... just make sure it's a 325/30 and not a 325/35.... 35 series will have rubbing issues.
-Seven
04-07-2019, 01:03 PM | #5 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Id love to put a 325 on as well but wasn’t sure if it would fit.
04-07-2019, 03:58 PM | #6 |
SABIO
12's don't look good.
Doesnt matter what offset. They will stick out past the fender. You run a 305 or 325 so the tire is stretched to help hide the wheel that is sticking way past the fender. If you put on a proper 345 it would be obvious how far they stick out. Go 11.5" or 11. Some have put a 325 on the 11 and it doesn't look to bad. You will be disappointed with the 12.
04-07-2019, 06:01 PM | #7 | |
-Seven
04-07-2019, 08:28 PM | #8 |
SABIO
I believe with the 19's you can get them in deeper. So less poke
04-07-2019, 10:27 PM | #9 |
diameter doesn't really matter with "poke" as much as offset does
-Seven
04-07-2019, 11:07 PM | #10 |
Drives: SS-6-SPD Join Date: Jan 2017
Go 20x11 with 305 or 315 tire ..
No need to go 20x12 .... |
04-09-2019, 11:06 PM | #11 |
Set up ordered
I ended up going with 20x10.5 front and 20x12 rear on blank wheels with custom made cnc'd offsets. Tires are 285/30 315/30. This package fits like a glove.
I'll post pictures soon. Thanks everyone for the replies Last edited by C4MSS; 04-12-2019 at 04:44 PM. |
04-12-2019, 05:14 PM | #12 |
Drives: 16 SILVER 2SS Join Date: Nov 2018
Can you post a pic showing how flush they are?
04-13-2019, 06:26 PM | #13 |
The front looks just like the 1LE's front with the tires' sidewall showing a hair pass the fender. The 12s in the rear look the same as the front in my case; whereas the 11s in the 1LE rear are flushed with the fender. Last edited by C4MSS; 04-13-2019 at 06:57 PM. |
04-13-2019, 10:10 PM | #14 |
SABIO
New wheels are new wheels.
Congrats. What are the wheels? Specs?
Thread Tools | |
