03-29-2019, 06:35 PM | #1 |
Drives: '17 Camaro 2SS 50th Anniversary Join Date: Feb 2009
Sway Bar Install Help!
I was trying to install the BMR front sway bar on my car. Was tightening the sway bar bushings down according to BMR instructions which show 35 ft/lbs and one of the bolts broke off. Has this happened to anyone else? Any ideas on a fix? As of right now I'm going to be running with no front sway bar...is that a problem if I stick to normal daily driving? Appreciate the help.
03-29-2019, 06:47 PM | #2 |
i had the same thing happen to me as mine was loose and a shop broke it
afe power took it in and replaced the studs with bolts and nuts as they built into the subframe hope this helps!
03-29-2019, 09:07 PM | #3 |
That does help. Thank you. Do you know how they got the stud out? Did the have to drill it out from the bottom or is there some other way of getting it out of the subframe?
04-01-2019, 11:40 AM | #4 |
i believe he drilled it out or hammerered it out but i looked at the gm diagram its literally built into the subframe which i almost had to order a new one until afe power came to the rescue lol btw my price it was like $700-800 plus labor
Thread Tools | |
