06-09-2018, 04:56 PM | #1 |
Drives: 2018 2SS Convertible MBM/Kal Join Date: Feb 2018
Removing trim around Steering Wheel Controls
Did a bit of searching, could not find an answer...
So, how do you remove the “chrome” trim around the steering wheel controls of a 2018 2SS vert? I want to paint/dip/wrap these trim bits, along with the trim around the instrument cluster and the shifter bezel. Thanks much!
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note: 2013 Caprice PPV. (“Company” car.) 1998 Cadillac STS 1996 Impala SS 1969 Cadillac DeVille Convertible 1993 Corvette 1991 Mustang 5.0 LX 1973 Alfa Romeo Spider 1986 Mustang GT T-top 1964 Falcon Sprint Hardtop. (First car, still have the key!) |
06-09-2018, 06:08 PM | #2 |
Drives: 2017 SS 50th Jan 17 2018 Join Date: Nov 2017
Hahahahahahahahahahahahaha
I just was at the decal place yesterday and asked the same question, there is a video on another thread that shows it being taken apart can’t post on the iPad but it is there the door handles need to be done for me as well and the vents on each side going to be fun. do the vents and door handles come off easy? |
06-09-2018, 06:13 PM | #3 |
look under technical modifications as I have be,led it up for you
06-09-2018, 10:08 PM | #4 |
Drives: 2017 2SS Camaro Join Date: Apr 2013
Here is a video from another post, don't know if it will help but it's worth a look. https://www.youtube.com/watch?time_c...&v=Z8vJSsa2ghA
06-09-2018, 10:11 PM | #5 |
Thanks for the info.
So the airbag has to come out, then the side modules. Then looks likes carefully lifting the side tabs on the trim. Hmmm. Need to decide if worth it.
06-11-2018, 01:09 PM | #6 |
Drives: 2018 Red ZL1 Join Date: Mar 2018
Just installed Red Paddle Shifters, so have some experience here...
Yes, made me nervous messing with the Air Bag... Watch the video referenced in thread. Disconnect the battery. Pull the airbag fuse. I used long Allen wrenches to stick in the little holes on each side of steering wheel. Like the vid, it takes a bit of messing to get the airbag out. I did one side at a time. I didn't feel like un-doing the airbag connectors, so i just zip-tied it to top of steering wheel to help hold out of way. Pull the little plastic emblem out at bottom of steering wheel. Friction fit so just pull. I didn't figure this out from the vid til 1/2 done, but makes real easy to get the trim pieces out...There is a plastic ring that goes all the way around the inside of the wheel that holds the right and left clusters in. Doesn't look like it does, but does. Friction so just pull. Get this out and they come out easy. You can then pull the chrome bezels off much easier. Looks daunting but not too bad. Hope helps. Jim |
06-11-2018, 08:38 PM | #7 |
Thanks Jim!
Car is a 2018 2SS Convertible. Mosaic Black Metallic/Kalahari interior. I have some Anthracite and Black Sapphire Plasti-Dip, as well as a spray can of AC Delco MBM paint. Want to do the “chrome” trim around the gauge cluster, the trim on the steering wheel, and the trim around the shifter. Will likely start with the Plasti-Dip and some Glossifier, so I can peel it if I screw up/hate it. Just need a day off without the kids running wild to do it. Maybe next weekend...
06-14-2018, 09:42 PM | #8 |
Drives: 2017 Camaro 2SS, Black/Red Join Date: Mar 2017
I made this a while back.... https://youtu.be/AUdnyVvp3p8
06-15-2018, 07:38 PM | #9 |
is there anything that can be applied or just painted on without removing all that stuff
07-14-2018, 08:46 PM | #10 |
[QUOTE=Stig eh;10219522]is there anything that can be applied or just painted on without removing all that stuff[/QUOT
Not really, you don't want a mod that doesn't look right and anytime you coat something. You're not going to want other components exposed, so you'd have to mask off the entire inside of your car which isn't practical. |
01-31-2022, 10:56 AM | #11 |
Drives: Camaro LT1 Join Date: Jan 2022
So I just did the removal and wow was that a pain in the butt. I painted my with a blue anodized auto paint.
Anyone know if that circle part can be preyed off so I can paint that as well? Last edited by saintnick; 01-31-2022 at 11:03 AM. Reason: Added photos |
01-31-2022, 10:17 PM | #12 |
Drives: 2021 Camaro LT1 Join Date: Oct 2020
i put some "carbon" pieces over the stock, they used 3M to apply. They looked great, but i couldn't stand the sharp edge at the top so i pulled them off.
like these |
02-02-2022, 06:40 AM | #13 |
Dyno Show Queen LOL
All of these parts are real carbon parts from trufiber.. they do have cover w dbl sided tape as well but this is the way to go!
I plan on making a thread to carbon my wheel.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 02-02-2022 at 06:53 AM. |
02-02-2022, 11:51 AM | #14 |
I agree wholeheartedly. Should I ever decide to reach for more carbon fiber in the interior, I'll want actual, quality replacement parts and not some stick-up covers with 3M tape. If I can't afford or justify the real parts, I simply won't buy anything.
