08-03-2019, 12:03 PM | #1 |
Drives: 2016 ss Join Date: Aug 2017
Mighty Mouse wild catch can
Hey guys, I have a 2016 ss with hellions twin turbo kit. I’m trying to install my Mighty Mouse catch can. And I’m not sure on what way to go with the clean side of the can. I have. A few vac taps on the intake mani side. For my blow off valves. And my boost gauge ref. The turbo kit instruction had me loop my lower valley and upper intake manifold vac lines. And from there I install tees. For all my stuff. Now going to install the clean side of the can. And I’m a little lost at what I should do.
Install the clean side to the upper intake port. And install tees. For my red in that same line? Or leave it how it is from the intake mani side with all my tees and remove the loop to valley lower port. And install clean side there? |
08-04-2019, 08:18 AM | #2 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I would simply unplug the hose from the lower valley port and run that over to your clean side of the catch can. Your dirty side of the catch can will run from the Oil cap adapter drivers side valve cover. Cap the lower valley port.
