08-15-2022, 08:05 PM | #15 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
08-16-2022, 05:24 AM | #16 |
Drives: 2024 Toyota Camry XSE Join Date: Sep 2017
lt4camaro, yes lowered the rear 1" with BMR springs. Can't offer a definitive answer to your question because the rear sway bar came off the same time as other changes. Never isolated that one thing. Best guess is it didn't hurt. 2021 goal was to improve the 60' and went from 1.5's to 1.462. For a bolt-on N/A car, that's not too bad.
2016 1SS - Bought: 8/2017 Sold: 12/2023
08-16-2022, 07:54 AM | #17 | |
08-17-2022, 12:22 AM | #18 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
2021 LT1 . No options . This was with a 1/4 tank and before I installed my aerospace front brakes which saved 50lbs. So I would guess 3230 with brakes . I still have the stock drivers seat and muffler . Just your standard weight reduction . Pass seat, rear seats, belly pan, front sway bar, lightweight battery, dragpak, washer fluid reservoir , rear trunk mat only, front bumper support , Headers and no cats also lose some weight . Car is an A10 so I would think a manual could be even lighter if it had the same stuff off the car .. |
08-17-2022, 07:11 AM | #19 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
If I do sway bars gone and light weight brakes that will put in the 3200’ with all the rest of advice on thread.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
08-17-2022, 09:44 PM | #20 |
2Spdsy
Blackbeast, 1200 for the front brakes . Just order the kit
08-18-2022, 08:27 AM | #21 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Racing brakes or V6 brakes
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
08-20-2022, 06:19 PM | #22 |
Seats are officially in now, used planted seat brackets to anchor them down. I had purchased a couple of seat sliders but couldn’t use them due to the height of the seats and no clearance up top. Got some nice hardware super grade bolts and snugged them down German style. These seats are not moving or going anywhere.
08-21-2022, 06:39 PM | #23 |
Drives: 98 Camaro Join Date: Apr 2022
I like this post
08-25-2022, 01:08 PM | #24 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
JHS, if you haven't installed your Edelbrock 2650 yet, you should weigh it and see how it compares to the your LT4 blower.
Baby Blue
11-04-2022, 07:47 PM | #25 |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
I have a lot of experience with the Anti-Gravity and other brands of Lithium batteries in MOTORCYCLES.
I have used them in at least 6 different motorcycle projects over the past few years, and they work fine, provided you understand how they work: - VERY high starting current capacity, BUT it deceases when the battery gets very cold. You should actually turn ion the headlights for a minute before cranking when the battery is cold, as that warms it sufficiently. - Don't get the very smallest capacity. Get one that is MODERATE. You STILL save at least 50% of the weight or more over a conventional battery. - To counter parasitic drain, keep the battery on a SMART, LITHIUM-rated battery charger. - Inabsence of any parastic drain, Lithium batteries will stay charged for many months even without a charger attached. Jim G |
11-04-2022, 07:53 PM | #26 | |
11-04-2022, 10:18 PM | #27 | |
- Brand? - Model no. or part no.? - Weight? And, how hard is it to get a Battery tender type wiring harness attached to it so that a charger can be easily plugged into it when it is in the garage? Is it reasonably accessible? Jim G |
11-05-2022, 11:53 AM | #28 | |
Pics attached. It was a solid 30 lbs heavier than the Antigravity one (17 vs 47 IIRC). I just wired up my charger to grab the large hot wire feed at the front power distribution block. When I’m done I just unplug the quick disconnect and tuck it back in by the block. Been doing it for 4 years with no issues even though it’s not right at the battery.
