08-11-2022, 12:35 PM | #1 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Curb weight? What’s the lowest?
I am starting a Camaro diet and I am wondering what do you think a reasonable weight reduction is for Gen 6 1LE? My goal is 3500 lbs or less.
Stock curb weight 1LE is 3754 lbs • front and rear seats gone • 4 cats gone • rear suit case muffler • drag pac 17 inch • interior parts • console gone • trunk parts gone • stock intake gone • plastic valve covers, engine covers gone Of course there’s the added mod parts that add back on.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 08-11-2022 at 02:33 PM. |
08-11-2022, 02:08 PM | #2 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
3500 is possible YES
Well I am at 3580 pounds currently without Fuel.
I have a set of track seats that are roughly 20 pounds lighter per seat than the stock SS seats were (Your Kirkeys are definitely lighter). Magnaflow back half exhaust (no suitcase). KOOKS 2 inch headers, lighter wheels (APEX SM-10 19 x 10.5) and Girodisc front rotors (-10 pounds). I still have FULL BACK seat setup, Full interior (including console) all accessories incl AC still installed, class 1 trailer hitch +20 pounds) The weight slip BELOW is with 6 gallons of fuel which weighs roughly 40 pounds so that's where I get the 3580 number. I have an A10.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 08-11-2022 at 02:20 PM. |
08-11-2022, 02:22 PM | #3 | |
The Kirkeys are 14 pounds. Has anyone taken off the front lower aluminum skid plate? It’s pretty big, I had to take it off to get a tool I dropped down there before. I should have weight it then.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
08-11-2022, 02:36 PM | #4 | |
My CURRENT TOTAL two front seat weight with brackets is 68 pounds compared to your KIRKEY setup at 28 pounds total (brackets???).. What seat brackets are you using??? You could also go with an ANTIGRAVITY battery and save another 30-35 pounds but I would NOT recommend that for a daily driver.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
08-11-2022, 02:59 PM | #5 | |
08-11-2022, 04:04 PM | #6 |
im 3623 with half tank of full with me in it 3823 one race seat rear seat delete antigravity battery lighter 20 inch wheels and full aftermarket suspension
08-11-2022, 04:20 PM | #7 | |
Thanks man for info, what did u pay for your battery and make if u don’t mind asking? I am seeing cheaper ones out there but wondering if there any good. There must be a set amp valve that’s needed for our cars to start. ( cranking power )
08-11-2022, 04:27 PM | #8 |
check out my post but i dont remember the price sorry its been about a year
https://www.camaro6.com/forums/showt...ht=antigravity
08-11-2022, 07:52 PM | #9 |
I'm currently at 3725 w/ 2 gal. and could easily get below 3700
'20 ZL1 1LE A10,
08-11-2022, 07:56 PM | #10 |
I agree, just take out the backs seats and your below 3700 easily.
08-13-2022, 05:41 AM | #11 |
Drives: 2024 Toyota Camry XSE Join Date: Sep 2017
Not exhaustive, but a few more things. 1) Everything out of the trunk including panels; 2) both sway bars (15 lb ea) just for track; 3) ditto on Anti-gravity battery; 3) drain the windshield washer tank; 4) Aluminum (and plastic) belly pan under engine. 5) Lightest wheels/tires you can find (for me was Bogart 14 lb. front, 21 lb. rear and Hoosier DBR 8 lbs each lighter than M/T. 3320 lbs. no driver, 1/8 tank fuel. 1SS
2016 1SS - Bought: 8/2017 Sold: 12/2023
08-13-2022, 05:52 AM | #12 | |
08-13-2022, 12:58 PM | #13 | |
No help on the door panels. Pulled only the passenger and rear seats from the interior.
08-15-2022, 08:02 PM | #14 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
