06-29-2022, 06:09 PM | #1 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Weapon X 160 thermostat
I installed the weapon x 160 thermostat and this week it failed with only about 1,200 miles on it. It was stuck solid and would not open.
Anyone else have any issues with this thermostat? I put in a stock GM thermostat for now, what is everyone else running? Katech has 174 degree thermostat.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
06-29-2022, 06:13 PM | #2 |
Drives: like an old lady Join Date: Jun 2012
the stock tstat on my car shows 178 on the road, sits around 188 hot idle. didn't see the point in swapping them.
06-29-2022, 06:24 PM | #3 |
A 160-degree thermostat is designed to maintain a lower engine operating temperature, which tends to make a little bit more horsepower and torque. Myself I am looking for any edge but I want a good quality make. This one failed pretty quick. Anything to give a head start to the engine cooling to prevent early detonation.
06-29-2022, 07:08 PM | #4 |
Shadow Gray '19 ZLE M6
160 Thermostat providing any benefit on modern engines is a fallacy. These engines are intended to run hot. In fact, you'll end up with worse gas mileage and will be putting out more emissions on a 160 thermostat.
Moreover, cylinder bore & piston ring wear are increased. Studies have shown engine wear is double with a 160 thermostat vs. stock. There is also debate over whether the engine oil needs to reach operating temperature to boil off any condensed moisture.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube Last edited by radz28; 06-30-2022 at 09:15 PM. Reason: deleted quote that was deleted |
06-29-2022, 07:41 PM | #5 | |
On an NA build there is probably not a ton of advantage with a lot lower stat. If I was NA, I’d probably run the Katech 174 which does not need tuning. On a FI car, I would definitely run the Katech 160 and tune for it. With a supercharger, running the temp lower let’s the fan cool your intercooler better, so that’s a no brainer. And just a PSA: a 160 thermostat does not mean your motor stays at 160. For example, with the Katech 160 my engine is typically in the 174-185 range on the street. Your fan settings play a massive role.
06-29-2022, 07:48 PM | #6 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Mishimoto has a 82 celsius 179 degree stat that looks just like the factory GM stat. My OE 194 stat usually reads temps in the low to mid 180s cruising and the Mishimoto runs a solid 15 degrees less all the time, high 160s to low 170s. I also have the fans coming on early at 185 to 190 degrees.
06-29-2022, 08:11 PM | #7 | |
You’ve been warned.
06-29-2022, 08:19 PM | #8 |
I have about 5000 miles on the stat, It has been rock solid and I monitor the digital read out temp guage constantly. This stat is a mirror image of the OE stat. I did have a issue back in 2016 with a Lingenfelter 180 stat and that did fail early but the design was totally different.
06-29-2022, 08:22 PM | #9 |
By the way, what actually happens to the stat when they die prematurely? they stick closed? open ? If its the seal, that is what the older different design did and that makes the car run to cool.
06-29-2022, 08:25 PM | #10 | |
So are you recommending to stay with stock thermostat? Anyone have the Katech thermostat and can chime in?
06-29-2022, 08:51 PM | #11 | |
06-29-2022, 08:53 PM | #12 | |
They stick shut (!), leading to overheating in the vast majority of cases I’ve seen over the past 4 years on these forums.
06-29-2022, 09:03 PM | #13 | |
06-30-2022, 05:57 AM | #14 |
I had TWO of the Mishimoto thermostats crap out, both with just a few months of use. JUNK.
IMO, go with a Katech thermostat if you want to make a change from stock. My experience with their thermostat was that it lasts for years, instead of just a few months like both Mishimotos had. |
