01-27-2022, 07:51 PM | #1 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Anyone tried the Y splitter for OBD II port?
Anyone here try the OBD II port Y splitter with good results? Just wonder because I want to run a N Gauge for HPTuners & another gauge. Which one is a good one? Any known problems associated with doing this?
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
01-27-2022, 08:57 PM | #2 |
Drives: 2016 Camaro Join Date: Oct 2017
I suppose the biggest concern is how much power the OBD II port pushes out and how much power the two devices require. Maybe you'll need a supplemental power source.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
01-27-2022, 11:05 PM | #3 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Instead of a splitter, look for a pass-thru connector like AEM uses on their AFR gauges.
The benefit of the pass-thru is the additional information is available to the other device on the plug. i.e., I can log my Wideband O2 with HPTuners. It's a simple process to add the channel.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
