01-11-2022, 02:28 PM | #29 | |
Hot Camaro
First of all, the weight of the two vehicle has a relationship to the amount of weight the vehicle will be rated to tow, and HEAVIER weights for the tow vehicle itself will lead to HEAVIER tow ratings up to the limits of what the tow vehicle can actually handle based on the construction of the vehicle. You're never going to get a 2000 lb tow vehicle rated to tow 15000 pounds. Second of all, your comment that nothing matters unless something happens is 100% irresponsible. Third, the tow vehicle in question will be able to tow an enclosed trailer with a car in it and be within the rated numbers so long as the hitch that gets installed meets the requirements as well. The rest of what you wrote has all been covered already, so I don't know why you're reiterating it like you're the first one to bring any of it up. |
01-11-2022, 02:32 PM | #30 | |
Hot Camaro
In the case of -some- of the trucks out there, a WDH is needed when trying to tow at or above about 60% of the rated capacity. It's important to know when one is necessary. |
01-11-2022, 02:37 PM | #31 | |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Agreed but people treat them like magical items that somehow mean you can tow what you should not be towing. RAM states 5000lb+ trailer and you should use a WDH.and proper set up of the WDH and trailer are KEY to safe towing
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
01-11-2022, 02:38 PM | #32 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Thanks for everyone’s input.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
01-11-2022, 02:43 PM | #33 | |
Ok...take the truck and fill it up with fuel. Hit a CAT sacle. 6400 GVWR minus the CAT number is all the extra weight you can have in the truck. Including passengers, gear, WDH and tongue weight. It will runout fast. For instance you use the 10 to 12% tongue calculation when towing an RV so if said rv weighs 10000lbs you should have 1000 to 1200 lbs of tongue weight. That comes off of payload. Payload is GVWR minus actual weight of truck. I will bet money if you put that truck on a scale you will be shocked
01-11-2022, 02:49 PM | #34 | ||
Hot Camaro
01-11-2022, 02:52 PM | #35 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
So you have a 12000lbs hitch MOST of the weight goes on the trailer axles in that case (depending on what the trailer axles can handle) The rest up to your 1000-1200lbs tongue weight includes whatever you put in the bed of the truck. That's why hitch type matters to offset tongue weights on vehicles with a better/more sturdy trailer. So your 1600lbs trailer you might want to consider the axles, or step up on the trailer options to get a heavier duty trailer... IF that becomes necessary. The OP did say money really isn't an issue if I remember right. So he can get an enclosed trailer with better axles and still be fine for his tongue weight. lol I realize we ALL are probably over analyzing the situation for the OP. But there are great details to be learned in this thread either way. In general OP 1600lbs trailer is fine and dandy, check the axle weight limitations though the more you can put on the trailer the more you can free up your tongue weight. So the fact you are getting 12000LBS hitch gives you options to get a better heavier duty enclosed trailer if you really want to. |
01-11-2022, 02:55 PM | #36 | |
Hot Camaro
Depending the hitch and receiver combo, WHERE that weight transfers to the truck can vary a bit (in terms of how far behind the axle). That's really the only way to alter actual tongue weight percentage because that distance is will multiple the weight differently as the distance changes. |
01-11-2022, 03:05 PM | #37 | |
When I made that statement I simply meant get a better trailer with heavier duty axles to free up weight on the tongue if need be. He can still put 200lbs of that 700lbs into the trailer and the other 500lbs into the bed of the truck The heavier duty trailer axles provide that versatility where as his 1600lbs trailer may not be able to carry much more than the car itself then he has to dump 720lbs of stuff into the bed of his truck or more if he has that much to bring with him. Then you have to consider space for all the equipment as well. In my case if I were to bring my car to the track I'd have 3 sets of wheels and 12 tires to bring with me for example. Edit: The tongue weight is not really as important to pull a trailer that is weighted down. As I mentioned earlier I pulled almost 11000lbs with no tongue weight. But I had the tires to do it in mud while my friend did not. What I mean is you are trading tongue weight limitations for towing capacity offset. You can tow without tongue weight, but you cannot tow with a lot of tongue weight. That is when you see people with their ass end suspension sitting on the ground they are over their tongue weight when that weight should be added to the trailer not the tongue. Hope that makes sense, I tend to be long winded sometimes sorry about that. Last edited by FlukeSS; 01-11-2022 at 03:36 PM. |
01-11-2022, 04:40 PM | #38 | |
Drives: ZL1 1LE on order Join Date: Nov 2021
It’s really screwed up to be honest. Fed and state laws. For some reason 26,000lbs combined sticks in my head. BUT from what I understand as long as you were within the ratings for your vehicle/trailer combo and towing as a civilian you’re fine. Example. You could have a 3500 dually and tow 37k lbs. Do that in business without the proper dot/CDL etc it’s gonna cost you a fortune. |
01-11-2022, 04:48 PM | #39 |
My suggestion,
Find a good tow forum and listen to those guys. Get it setup properly, drive slower than usual and mind yourself. Think of it the same way as racing your car; you make sure the brakes, tires, lug torque, oil are all good... think of towing like that, make sure you and everyone around you are safe!
01-11-2022, 04:48 PM | #40 | |
Hot Camaro
Generally, you want to target something like 15% of the total gross trailer weight for tongue weight. This is "heavy enough" to ensure the rear wheels stay on the ground with good traction and "light enough" that you aren't also lifting weight off of the front axle. For a 10k gross trailer weight, that would mean roughly 1500 lbs (give or take) which is right in line with what you're saying. When you described pulling 11k with no tongue weight, I believe you were basically describing dragging the entire load over a short distance (think "recovery" as opposed to actual longer distance towing). Additionally, you were effectively adding your own traction to the overall construct. So, while there was 11k of weight behind you, the "original" tow vehicle was contributing to some portion of that once -IT- started to gain its own traction. The primary point I was trying to convey is that, regardless of the weight of the loaded trailer, one should target somewhere around 15% of that total weight to be on the tongue of the trailer. That helps with steering, braking, acceleration, and overall smoothness of towing (too little tongue weight, for example, and the trailer will be walking back and forth behind you). |
01-11-2022, 04:49 PM | #41 | |
Hot Camaro
Once you're "for hire", I think the rules change regardless of weights. On the flip side, a 12k trailer requires DOT placards and all of the commercial stuff UNLESS you are able to get a waiver as non-commercial which will also require large letters on the trailer (and the tow vehicle?) that say NOT FOR HIRE. |
01-11-2022, 04:56 PM | #42 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Nah, I'm just looking for an excuse to upgrade.
